SS Brake Lines - Stock Excursion
Old 06-08-2018, 06:06 AM
Oldschool57's Avatar
Oldschool57
Oldschool57 is offline
I'm getting ready to replace the rubber brake lines that attach to the calipers. Help me find Stainless Steel brake lines for my stock 2001 Excursion!
I can only find SS brake lines that go with lift kits, which I do not have.
Any help is appreciated.
Old 06-08-2018, 07:23 AM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Crown Performance: Stainless Steel Brake Lines - Braided Brake Hoses for Cars, Trucks & SUV
give them a call if you don’t see what you want on the menu.
They make them in-house and are a major supplier to the industry.
Old 06-08-2018, 07:57 AM
Oldschool57
Perfect, I just placed my order! Thanks again!
Old 06-08-2018, 09:27 AM
Greenscobie86's Avatar
Greenscobie86
Greenscobie86 is offline
I just put the Russel SS lines on my stock truck even though they are rated for lifted trucks. The extra length didn't really matter...
Old 06-08-2018, 09:58 AM
pirate4x4_camo
Originally Posted by Greenscobie86
I just put the Russel SS lines on my stock truck even though hey are rated for lifted trucks. The extra length didn't really matter...
worth keeping an eye on them they are not rubbing on anything. I have seen several that did not get quite the right twist when installed and they ended up getting a hole rubbed in them.
Old 06-08-2018, 10:04 AM
Greenscobie86
Yeah I recall that back when I installed them on the white 03 truck I sold. I simply made sure they were bent out of the way and put some plastic conduit on them for protection. FWIW never had an issue for the couple of years I owned the truck. I think there were also talks of the Russell lines being incorrectly labeled from side to side, which caused issues with installation/mounting, I don't think mine were though. Either way good point for those that aren't in the know.
Old 06-08-2018, 04:46 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
You are correct on the incorrect labeling. Mine were switched side to side on the fronts!
Old 06-09-2018, 08:51 AM
Tbug05LTD's Avatar
Tbug05LTD
Tbug05LTD is offline
I replaced all of my rubber brake hoses with Russell RUS696490 which were supposed to be for something like 4-5" lift but they were no longer than the stock hoses on my 2005 Ex 4wd with X/C springs from ATS. Been about 2 weeks now, no issues. Brakes are much stronger than before but to be truthful I put on front Powerslot cryo rotors and Hawk green pads along with new Power stop calipers and a complete flush.
Old 06-09-2018, 01:44 PM
Projectlittleredf250's Avatar
Projectlittleredf250 is offline
how do you like the power stop calipers?
Old 06-09-2018, 05:37 PM
Tbug05LTD's Avatar
Tbug05LTD
Overall brakes are much stronger, not sure how much the Powerstop S4790 calipers contributed to it. They were an exact replacement and the red color looks nice except you can't see them through my solid wheels.
Old 06-10-2018, 07:56 AM
Patriotic Rottweiler's Avatar
Patriotic Rottweiler is offline
I installed the Crown Performance 5 piece SS brake hose kit on my stock height EX and have not had any trouble with them. You might have to call to get the 5 piece set as it wasn’t listed on their website several years ago when I purchased mine.
I also have the Power Stop caliper/rotor/pads set and they are still great as well. No problems from any of it.
Good Luck on your selection/installation.
Old 06-13-2018, 12:06 PM
96firephoenix's Avatar
96firephoenix
96firephoenix is offline
I've got these too, and compared to excursions I've driven with stock brakes, they are a good bit better, but I also can't say if it's the calipers, the pads, or the rotors... or just all of those being brand new, lol.
as for the looks... if you have both rear calipers on the back side of the axle, anyone behind you can see the big beefy red calipers. Who needs trucknutz when you've got Powerstops?
Thanks for the feedback on the stock height excursion fitment.
Old 12-17-2018, 11:01 PM
R&T Babich's Avatar
R&T Babich
R&T Babich is offline
Our 2wd Excursion has 130k on the OEM brakes and we tow a 7k TH.
I've been looking at getting Powerslot cryo rotors and Hawk LTS pads when it's time to replace them.
It seems like it would be a good time to change the hoses and bleed the brakes, too.
Are the braided SS hoses worth it or should I stick to OEM rubber hoses?
I've read the SS lines do not come with support brackets.
I do not see a listing of SS lines for the 2wd from Crown Performance.
The Russell RUS-672440 SS kit at Summit says it fits RWD and 4WD, but is that right there is no difference?
ItsAFord55
05-25-2013 06:19 PM
fhartell
03-16-2004 12:32 PM
Quick Reply: SS Brake Lines - Stock Excursion
