No brake lights
Old Jun 8, 2018 | 12:53 AM
Risingphoenixtowing's Avatar
Risingphoenixtowing
Angry No brake lights
My blinkers work and the taillights work when the lights are on. But not the brakes when I press on the brakes. And we already tried the switch near the brake pedal and it didn’t fix the problem. Any help with troubleshooting would be greatly appreciated. TIA
1990 F350 7.3
Old Jun 8, 2018 | 01:48 AM
DarkOverCast's Avatar
DarkOverCast
I'm sure you've already tried fuses and such so the next thing I would check for is weather or not you have power at the brake pedal switch with a simple test light.
If you don't have one this is a definite item for the glove box especially if you pull trailers often
Be sure to test the light on a known power point on the fuse box to make sure it has a good ground.
If no power is present search for a fusable link under the hood. It's like a bump in a wire and it's an internal wire sized to burn out if there is a short or if it just gets old. Not sure where the location would be on your bricknose but they're normally between the battery and the fire wall somewhere in the wiring. Anything that has power without the key will have a fuseable link such as headlights, horn, ect
If your getting power to the switch, there is a connector on your steering column that's u shaped, try unplugging and plugging it several times. I've had this fix all kinds of weird stop light/blinker issues. I also run a zip tie around it and tighten the **** out of it because the factory retaining clip normally breaks when you try to release it.
Old Jun 10, 2018 | 12:04 AM
Risingphoenixtowing
Thank you very much. I’m gonna troubleshoot on some of these suggestions tomorrow.
Old Jun 11, 2018 | 01:05 PM
jmuenchow's Avatar
jmuenchow
I’ve had trouble in the past and my solution was a new turn signal switch.
Old Jun 18, 2018 | 11:57 AM
Leroy Unlisted's Avatar
Leroy Unlisted
My brake lights failed long ago, I just ran a fuse to the pedal switch, then ran primary wire under the bed, disconnected the old wires and ran that primary wire directly to the bulbs .. Other side to ground on the frame..
It's the wrong way to do it, but it does the job and took fewer than 2hrs and no troubleshooting or new parts required..
Old Jun 23, 2018 | 11:41 AM
Etone's Avatar
Etone
In my case, wire under the steering wheel rubbed off insulation. pulled off steering wheel, wrapped black tape around bare exposed wire. problem solved
Old Jun 23, 2018 | 12:59 PM
RaymondIV's Avatar
RaymondIV
Right, the brake light circuit has to run through the T/S switch.
RustyTank
26
Jun 18, 2019 11:06 AM
Larzon
Nov 18, 2012 06:56 PM
tlb
Jun 12, 2009 10:17 AM
7283-F250
Jul 27, 2006 08:00 PM
AaronW
Jul 28, 2002 09:12 PM
