'75 F150 Gear Issues
Old Jun 4, 2018 | 10:08 PM
Mjoener's Avatar
Mjoener
I'm brand new and this is my first older truck. I bought it for a fun project and to improve my mechanical knowledge.
Last fall I was driving it around and got it stuck in one of my fields, it's my "putz around the farm" truck. And I think I striped the linkage in the steering column. Any tips on a quick diagnosis before I tear out the steering column and have a look? It only goes in drives forward, no reverse or park. Not even sure if it is in Drive as you can move the shifter freely without depressing the brake.
Pics for fun.
Old Jun 4, 2018 | 10:47 PM
texinwa's Avatar
texinwa
Check the transmission shift linkage where it connects to the selection lever on the transmission. There is adjustment there and the linkage may have slipped out of position.
Old Jun 7, 2018 | 07:42 AM
Mjoener's Avatar
Mjoener
I found the issue. Where the shift linkage rod connects to the transmission, there was a bolt that locks into the linkage, it had been dislodged. I loosened the bolt and moved it after lining it up with P and then re-tightened it. Must've dislodged when I got it stuck on a mound.
Old Jun 7, 2018 | 10:08 AM
FuzzFace2's Avatar
FuzzFace2
BTW older cars & trucks you did not need to depress the brake pedal to move the shifter and on some new stuff to release the emergency brake.
How did we all live this long with out all the safety crap! And don't get me started on self driving / parking, stopping cars and cameras.
Dave - - - -
Old Jun 7, 2018 | 10:27 AM
Mjoener's Avatar
Mjoener
Right?! It was all so simple back then. I've got a 2016 Focus and the thing blows my mind on all the computer stuff. I'm afraid to get curious about whats under the hood!
Old Jun 7, 2018 | 12:21 PM
EQCMCAT's Avatar
EQCMCAT
Agree, seems allot of new vehicles no longer have an accelerator cable, they've been replaced with a relay, of which I can't seem to get comfortable with.
Old Jun 7, 2018 | 02:40 PM
mark a.'s Avatar
mark a.
Maybe it came apart because the cab is sinking on the drivers side...
Old Jun 7, 2018 | 02:50 PM
flatbedfordguy's Avatar
flatbedfordguy
Agree. How are your cab mounts? Rusty (sinking) cab mounts will play havoc with that linkage.
Old Jun 7, 2018 | 03:08 PM
Mjoener's Avatar
Mjoener
I think they're ok. However, I googled it, and in all honesty, IDK where those are... Seriously really new at this!
I'm positive it was yanked out in the field, I was stuck over a mound, bottoming out back and forth.
I'm planning on starting a thread with the different issues I'm encountering and improvements I make. Kinda a build thread, but mostly a learning thread.
Old Jun 8, 2018 | 05:13 AM
meangreen92's Avatar
meangreen92
You can see the cab mounts by looking through the rear of the front wheel openings. Look for a sort of triangular-shaped box on the lower front of the firewall, in the vicinity of the frame rails. The mounts can look good from the outside, but be disintegrating from the inside. Or the bottoms of the mount 'box' can be rusted away, with the rubber isolator bushing pushing up through the box.
Old Jul 20, 2018 | 12:59 PM
Looneytoon's Avatar
Looneytoon
A bit late but can you post a pic of your linkage rod? I think mine isnt the right one and i cant seem to find a picture of one online
Old Aug 9, 2018 | 11:03 AM
Mjoener's Avatar
Mjoener
Linkage Rod
This is the piece that keeps falling out. I am unsure of what part I am missing. Any ideas?
JC83
Feb 15, 2019 02:00 PM
Mark James Newburn
Jul 24, 2018 06:16 PM
veetwelve
Aug 31, 2013 01:08 AM
ColdRavioli
Mar 31, 2011 08:04 AM
EZTrader
1978 - 1996 Big Bronco
Sep 9, 2003 05:03 PM
