Transmission or Clutch Problem
Old Jun 2, 2018 | 02:23 PM
NewOldFordOwner's Avatar
NewOldFordOwner
I bought a 1993 F-150 4x4 with a 5-speed and 300 engine a few months ago. The slave cylinder quickly blew out on it. I put in a new clutch, pressure plate, pilot bearing, and slave cylinder. I also changed the input shaft seal and plugged the 3 holes in front of the shifter. The truck drove great after that and I've put about a 1,000 miles on the new clutch with no issues. However, yesterday while driving home, I downshifted from 4th to 3rd and when I released the clutch the engine just revved. I stepped on the clutch again and moved the stick again but the engine still just revved. I was able to coast to the side of the road. I tried all the gears and nothing happened. I got under the truck expecting to see fluid everywhere but there wasn't any. I pulled out the plug to look at the slave cylinder and everything was dry. I got a tow home and afterwards tried it again. It takes off now but I cannot get going faster than 20 mph and the engine revs to high RPM. Any ideas?
Old Jun 2, 2018 | 07:23 PM
White 97 xlt's Avatar
White 97 xlt
First off, Welcome to FTE!!!
It sounds like the transfer case got into neutral (wouldn't move), then made it to 4 low somewhere being towed home and being monkeyed with..
Just a guess but worth checking....
Old Jun 12, 2018 | 08:33 PM
NewOldFordOwner
Thank you for the suggestion! I was so single-minded, I couldn't think of anything other than the clutch. It did turn out to be the transfer case. I tried switching from 2WD to 4hi and 4lo, but couldn't. I ended up pulling the transfer case and only found about a cup of fluid in it.....fluid that looked like it had a lot of glitter in it... After opening it, I decided to go to a junkyard and get another. I'm still surprised I never heard a sound from the transfer case and even more surprised it could still limp up to 20mph! Now I just need to figure out how to tell when one needs rebuilt. Thanks again!
longpoleman
Aug 3, 2008 11:39 PM
89tankinhalfton
Mar 5, 2007 08:09 PM
5.0 ford
1983 - 2012 Ranger & B-Series
Oct 17, 2006 07:43 AM
raldo_gtm
1978 - 1996 Big Bronco
Oct 14, 2005 10:06 PM
cmlind
Oct 7, 2004 03:40 PM
