adjustable track bar needed with X codes?
Old Jun 14, 2018 | 11:18 AM
  #31
wpnaes's Avatar
wpnaes
In theory (lol theorem), but interested if anyone here has taken the time to measure (not trivial) and calculate, or jut go by ‘feel’.
Old Jun 14, 2018 | 11:46 AM
  #32
SmackDaddy's Avatar
SmackDaddy
I can measure my stock track bar and measure my longer adjustable from hole to hole and based off fender to hub distance give you a decent estimation.
Old Jun 14, 2018 | 12:38 PM
  #33
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Originally Posted by SmackDaddy
We should all know the formula.
https://en.wikipedia.org/wiki/Pythagorean_theorem
if A is the distance between the axle and the frame and B is the distance between the the center of the leaf springs the problem becomes exactly where to measure and how to measure each accurate to 1/32
The A measurement would either need to account for the point on the axle that intercects the track bar mount and the point on the frame the the track bar mounts since both of these are the piviot point. Also you would need to verify both sides were sitting perfectly level.
No easy or relible way to get those measurement, so the “formula” I was suggesting would take that into account but measuring from the hub to wheel well.
Old Jun 14, 2018 | 12:41 PM
  #34
pirate4x4_camo
FTE Remembers
I measure, going by feel assumes you can accurately eyeball the axle being centered. My eyecrometer is not that precise.
Old Jun 15, 2018 | 06:03 AM
  #35
loganj01's Avatar
loganj01
The height will change. The base of the triangle formed by the track bar and the axle will stay the same. In theory you should be able to measure the distance (height) from the axle to the track bar mount before you make any changes and measure it again after you install the new springs. Using a^2 + b^2 = c^2, you should be able to calculate the exact length needed for the new track bar to return the axle to it's stock position. Does anyone actually do all this? Probably not. The guy at the alignment shop said another half turn on the adjusting sleeve would have made mine perfect but it bottomed out. He said it was good enough and I don't know enough about alignments to say otherwise.
speakerfritz
Sep 29, 2017 04:57 PM
jbravata2
Mar 2, 2014 07:04 PM
Storm
Oct 28, 2007 09:53 PM
basstardo
Mar 24, 2005 05:17 PM
mooktank
Offroad & 4x4
Mar 4, 2003 07:25 PM
