Sponsored by: Real Truck
Trucks down for the count...
Old Oct 27, 2007 | 09:10 PM
Storm's Avatar
Storm
Well we worked on it only to find a mess of things.. Turns out Ford fubar'd the Lift install and my Pitman Arm dropped a ways down the steering shaft.. It doesn't look pretty.. Shes parked until it's fixed, too risky to loose my steering.. So the list of replacement is;
- Tie Rod end that hooks to Pitman arm.
- Pitman Arm drop as we think its damaged.
- Adjustable Track Bar
Does anyone know of a Adjustable Track Bar that is good for our trucks? I'm on crunch time, this has to be fixed this week..
*Nevermind I found out that Donahoe has a Adjustable Track Bar, its just called a Pan Hard Rod lol
2004 F250, 6L PSD, 4WD..
Old Oct 27, 2007 | 09:58 PM
rbloodhound's Avatar
rbloodhound
Sorry about your truck. What can I do to help
Old Oct 27, 2007 | 10:51 PM
Kep4's Avatar
Kep4
Jäger
Got the Donohoe adjustable Panhard rod on mine and it's a very heavy duty unit!
Hope you get it fixed soon.
Old Oct 27, 2007 | 11:48 PM
Storm's Avatar
Storm
Thanks ya'll.. I'm ordering parts this week and hopefully it'll be fixed thursday.. I have to get a Tie Rod end (one that hooks to Pitman arm) from Ford, then the Donahoe Pan Hard bar since the truck ended up being installed with the factory track bar, which is binding the suspension.. As well as another Drop Arm.. Looking at about $300 in parts, nothing too crazy, just worried the hell out of me.. Drove 65 miles at 45 incase the thing let go..
Old Oct 28, 2007 | 07:55 AM
rbloodhound
How did you find the problem?
Old Oct 28, 2007 | 10:08 AM
Storm's Avatar
Storm
One of my friends was looking at my lift kit when he spotted that the pitman dropped down the steering box spine..
Old Oct 28, 2007 | 10:13 AM
heidiandmax's Avatar
heidiandmax
Wow,did the nut back off allowing it to movelike that?Thats scary!
Old Oct 28, 2007 | 10:19 AM
Storm's Avatar
Storm
We think so.. I paid the Ford House to install it.. I came back for all 3 intervals to torque everything down... Normally after 2-3 times, once they are torqued, their not going anywhere.. So we think Ford didn't tighten it down.. I'm not about to trust them again so I'm repairing the parts myself..
Old Oct 28, 2007 | 10:30 AM
heidiandmax
Sure glad you found the problem before it failed.....
Old Oct 28, 2007 | 06:39 PM
lowet's Avatar
lowet
If you use the nut over, make sure you put some red locktite on it and make sure you get it sucked up tight, I have seen a couple lifted trucks with the pitman loose.
Old Oct 28, 2007 | 07:17 PM
Storm's Avatar
Storm
Thanks lowet! We're getting parts shipped in monday and will fix it asap.. I'm just glad we found it.. Had this happened on the road, it wouldnt of been pretty :-\
Does anyone know for sure, the pitman is suppose to be right against the steering box right? You shouldn't see anything from steering box housing to the pitman.. Even where the marks show that it dropped, was still a quarter inch gap between the steering box housing and the pitman arm.
Old Oct 28, 2007 | 07:21 PM
Matts72's Avatar
Matts72
There is a little gap, but its only about an 1/8" or so...
cparks's Avatar
cparks
Yes there is supposed to be a gap. The shaft on the steering box is tapered so the pitman arm can't go up tight against the box unless something is wrong. If for some reason it did, then the steering would be tight as it would be rubbing on the box.
Old Oct 28, 2007 | 09:53 PM
Storm's Avatar
Storm
Awesome.. Thats what I needed to know..
Thanks!
