Overheating v10
Old Jun 8, 2018 | 01:54 PM
tamarijn1's Avatar
tamarijn1
Overheating v10
Was going down the highway the other day doing about 70 and all of a sudden the truck overheated. Pulled over and let it cool down, turned the heat on and drove home with no issues. has approached overheating several times since but I have turned off the engine before it did. It's a 2000 Ford excursion V10 with 145,000 miles on it. I flushed the system and changed the thermostat. Had a sniffer test done and the heads seem to be fine. not sure if the water pump and radiator are original. upper radiator hose gets extremely hot, but lower radiator hose and degasser lukewarm at best. If I let it idle without the heat on, it will overflow due to pressure, not heat. The two mechanics at the garage are not sure what the next step is, any help or advice would be appreciated.
Old Jun 8, 2018 | 02:09 PM
Greenscobie86's Avatar
Greenscobie86
My neighbors 5.4 Expedition had a failed water pump that exhibited similar symptoms. Once we removed the pump from the block the impeller blades were almost completely corroded off, thus not providing any flow. Took a thermostat and a few coolant flushes to figure out that problem.
May not be your issue but a new water pump is cheap.
Old Jun 8, 2018 | 02:15 PM
tamarijn1's Avatar
tamarijn1
Thanks. I would think it has to be either the water pump or the radiator or both. Can't think what else it would be.
Old Jun 8, 2018 | 02:29 PM
ExxWhy's Avatar
ExxWhy
I recall a few rare stories about getting an air pocket in the system. Did it start this problem after the coolant change?
A bad cap will also release pressure and coolant, they are finicky.
Old Jun 8, 2018 | 02:34 PM
tamarijn1's Avatar
tamarijn1
Sorry, no I did the coolant flush after the problem started and I did also put on a new rad cap.
Old Jun 8, 2018 | 06:05 PM
WE3ZS's Avatar
WE3ZS
I'm also thinking possible clogged radiator, what was the condition of the old coolant when you did the flush? Was there a lot of scale and solids in the old when drained? Was it very dirty looking? Does the lower radiator hose get hot when its overheating or on the verge of overheat?
Old Jun 8, 2018 | 06:16 PM
tamarijn1's Avatar
tamarijn1
The coolant was in good shape. Lower hose has been lukewarm each time. That's why I feel it's not circulating correctly. I love this truck, but I cannot afford a head gasket job. I have over $7000 into the lift, wheels, tires and paint job and that was affordable prior to my marital separation. The motor went on my 07 expedition a few months ago, so this is the only vehicle I have left.
Old Jun 8, 2018 | 08:30 PM
WE3ZS's Avatar
WE3ZS
You could drain and capture the new coolant and try to do a large volume surge test through the radiator. Disconnect the upper hose from the T-stat housing and remove the lower hose from the radiator. Then with the aid of a large funnel hit the upper hose with as large of a shot as quickly as possible, like a 5 gallon bucket and observe the lower outlet flow, it should drain out nearly as quickly as what you can dump into the top hose. If you hit it pretty hard with a lot of water and the outlet is slow to drain you are looking at a clogged radiator.
Old Jun 9, 2018 | 09:05 AM
tamarijn1's Avatar
tamarijn1
So it's not a clogged radiator from what I can tell. Equal stream of water out of both hoses and no debris came out. so is the verdict a new water pump do you think?
Old Jun 11, 2018 | 08:57 AM
tamarijn1's Avatar
tamarijn1
Could some of the tubes be partially blocked and causing this problem in the rad? Some flow is happening, but not enough? Any suggestions about a good rad cleaner or I have read even vinegar. Want to try a few more things before I dump money into a new rad and water pump. Thanks.
Old Jun 11, 2018 | 08:15 PM
tamarijn1's Avatar
tamarijn1
OK, I really need somebody's help. Replaced the radiator today which was partially clogged, but the truck still overheats unless I turn the heat on. Then it operates normal temperature. Without that, it red lines and pukes. Even with the new rad, the lower rad hose is still lukewarm at best. my understanding is it should only be about a 20 to 30 degree difference from the top rad hose. Ran a therm gun to verify that. I'm not losing any fluid in the truck runs great, except for having the heat on which is not great in the summertime.
Old Jun 11, 2018 | 08:32 PM
ShelbyHauler's Avatar
ShelbyHauler
Did you test/replace the thermostat? If it's not opening fully or at all that could be why turning on the heater is keeping it from boiling over.
Old Jun 11, 2018 | 09:07 PM
tamarijn1's Avatar
tamarijn1
New thermostat, new radiator, flushed the system, pressure tested, water pump seems to be fine.
Old Jun 12, 2018 | 08:39 AM
Greenscobie86
Does it overheat while parked and idling or does it overheat when you start driving around?
Old Jun 12, 2018 | 09:12 AM
tamarijn1's Avatar
tamarijn1
Both. Running the heat is the only way to stop it from overheating. How high does the front end need to be to definitely purge the system? With the rear heat unit, i'm wondering if there are still air bubbles. I don't have ramps, but I'm sure I could find a very steep hill and try purging some more.
