mirror replacement on explorer?
Old Sep 20, 2003 | 12:34 AM
GucciSock's Avatar
GucciSock
Ok here's another question...
The newer model explorers have those mirrors that have the light built in so that when you turn your blinker on, the corresponding red arrow will light up and blink in the mirror, as an added safety feature.
Mine is a 2000 explorer but I would love to put some of those newer kind of mirrors on there...I have power mirrors now.
Anybody done something like this??
I know it could be done...I suspect that, if all else failed, you could splice the wires in yourself...looks like all it would need is the wires to control the power mirror part (which might be cross model compatible) and then the hookup for the blinker part...it must just hook into your blinker wire to get power.
Any ideas??
Old Sep 20, 2003 | 01:26 AM
ford_tr_man's Avatar
ford_tr_man
what kinda mirror's are you talking about?
the mirror's an the 03-04 explorer's are the same as your truck's they have been the same sense 1995 could it be you where looking at a 03 expy?
BTW it's only 3 bolt's and the mirror is off
Old Sep 20, 2003 | 08:24 AM
marragtop's Avatar
marragtop
I think the original post is referring to the mirrors on the Expeditions and Navigators. I haven't seen them on any Explorers.
Old Sep 21, 2003 | 11:09 PM
GucciSock's Avatar
GucciSock
yes i meant to say expedition but I was thinking about my explorer
but still, I bet those expedition mirrors would fit right on an explorer?...they basically look identical..
Any thoughts/experience with this?
Thanks!
Old Sep 23, 2003 | 12:44 AM
ford_tr_man
no!! there's no way they will fit TOATLY different door diff shape there's no way
sorry
Old Sep 24, 2003 | 10:02 PM
ottosmom's Avatar
ottosmom
There is a product you can stick to your existing mirrors and splice into your directional signal lights. They are called Nextlight Turn Signal Mirror Lights, and I found them on eBay. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2434264899
Old Sep 25, 2003 | 08:42 AM
Centex's Avatar
Centex
Have you tried the website that makes the mirrors for Ford?
http://www.kwmuth.com/products/kits/200-0037.htm
Another, but more involved method is to:
1. buy the nextlights from ebay
2. remove the mirror from the head
3. Cut a "V" into the black plastic that holds your mirror
4. mount the nextlights with epoxy
5. reinstall mirror onto head unit and wire into harness.
This is more involved but LOTS cheaper, and works just a well.
The LEDs will show through the mirror.
Old Sep 25, 2003 | 09:30 AM
CobraXP's Avatar
CobraXP
I thought I saw a newer Explorer yesterday that had lights on the mirror?!?!? Do the 02's and 03's not have it?
If you could find a slim enough light, it would not be hard to modify OEM's to get it in. Hard part would be finding the light...
Old Sep 26, 2003 | 03:07 PM
Centex's Avatar
Centex
If you download the installation instructions from Muth (Page 8), you will see that there is quite a bit of room between the mirror and the Housing. The nextlights are about 7/16" thick, subract 1/16" inch depth for the plastic holding the mirror on, and you only have to worry about 3/8" of protrusion. Lots of room...
I don't know if the 02-03 Explorers have the factory lights. I've seen them around, but since Muth makes them for Ford, It's hard to tell it they were a factory option or aftermarket.
Old Jun 16, 2004 | 12:14 AM
GucciSock's Avatar
GucciSock
yeah
I ended up buying the muth signal mirrors.
The only way you can tell is if you can view them with the vehicle stopped I'd say. The factory ones and the aftermarket ones look identical just to see the vehicle going down the road.
I did the same thing on my 2000 explorer and let me tell you...WHAT A PAIN!!!!!!
Installing the Muth mirrors on my 02 explorer was relatively easy, except that I never could find the blinker wires in my wiring harness anywhere, so I had to end up slicing a wire in right at my front blinker and running the wire from there. But, snapping the actual mirror into my old mirror housing was damn easy compared to my old explorer....
On my 2000 explorer..forget it! I broke one of my mirrors trying to switch them out. It is VERY tricky getting the old mirror out, and even MORE tricky trying to reseat the new signal mirror into place. There's virtually no room to work with and you have to try and make those yellow ***** pop back into place....grrrrrrrrrrrrr! On my 02, there is ONE notch..you just pry on it with a screwdriver and the mirror pops right off...then the signal mirror pops right back on...no ***** and motor arms to deal with, very easy!
Old Jun 22, 2004 | 02:49 PM
Msp541's Avatar
Msp541
I placed the Signal Mirrors on my Mountaineer from MUTH SYSTEMS and they were pretty easy to install plus it looks like that factory look too. Good Luck!
racerx6466
Feb 18, 2012 10:43 AM
Wakeboarder141
2004 - 2008 F150
19
Nov 3, 2006 03:47 PM
jetjock16
Apr 4, 2005 07:26 PM
