Sponsored by: Real Truck
4x4 wheel spin
Old May 29, 2018 | 05:15 PM
z4racer's Avatar
z4racer
7th Gear
4x4 wheel spin
I have a 2002 F350 7.3l and having challenges with the 4x4 system and it made me wonder how does it work.
In 4x4 high i have one rear wheel spinning and 1 front wheel spinning
In 4x4 low it seems that only one rear wheel is spinning. I think this because it will spin much easier than it does in 4x4 high. Something wrong here. I do hear a loud click when switching from 4x4 high to low.
In 4x4 high, i know the "auto" hubs work off of vacuum, is vacuum still required in 4x4 low?
the system will build on vaccum but it does leak down, Small vacuum lines seem to hold a vacuum the larger vacuum line, the final 1.5 feet to each hub seem a little too large and I think leak.
Question: Should I expect all 4 wheels to spin in 4x4 low?
Old May 29, 2018 | 05:26 PM
Buliwyf's Avatar
Buliwyf
You should get at least one front and one rear wheel spinning in 4L. Try manually locking the hubs.
Old May 29, 2018 | 05:30 PM
z4racer's Avatar
z4racer
7th Gear
I tried manual locking the hubs as well. From my understanding that takes away any need for vacuum.
I always thought the difference between 4h and 4L was that all 4 wheels would spin, like a straight axel. I guess 4L just changes the gearing, thus more torque.
Old May 29, 2018 | 05:32 PM
85e150's Avatar
85e150
With open differentials if traction is limited, it is possible that one front and one rear will spin.
If your truck had a limited slip differential, it may be worn to the point where it is no longer effective, rendering it basically an open differential.
All other things being equal, it should be easier to spin the tires in 4x4 low, as you have more reduction and torque multiplication in the drive train.
Again, in really poor traction conditions, 4x4 high will spin and spin a lot faster since it is higher gear with more wheel speed at any given rpm than low range.
If your hubs are vacuum, you need vacuum at all times, high or low.
You should correct the vacuum leaks as soon as possible.
As for all 4 spinning in 4x4 low, no, not always.
Old May 29, 2018 | 05:34 PM
85e150's Avatar
85e150
Originally Posted by z4racer
I tried manual locking the hubs as well. From my understanding that takes away any need fro vacuum.
You got it while I was typing the other response. 4x4 systems like this lock the front and rear together, but do not change your axle differential action.
Old May 31, 2018 | 06:26 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Are you sure the tcase motor is engaging 4low? They click u hear oa the motor moving the tcase lever BUT if it was never used or rusty the motor tries to engage 4low but cant. So its stuck between 4high and 4low...you'll still have the rest tires mo ing but will loose the engagement on the front axle. Also the 7.3 when in 4low YOU WILL KNOW! The motor whines and it just CRAWLS with an absurd amount of torque, no missing that
Old May 31, 2018 | 08:15 PM
00t444e's Avatar
00t444e
If you lock the hubs manually they are supposed to work without vaccum. 4x4 low is a 2.72 reduction gear for increased torque multiplication at lower speeds. The only way you can have all 4 tires spin in 4x4 is if you had lockers or working limited slip differentials in the front and rear axles. The factory configuration is an open front differential, and the rear can be either an open diff or a limited slip that isn't that effective when new and it wears out over time and becomes an open differential.
beeser
Jun 19, 2017 04:02 PM
guessrow
2004 - 2008 F150
Oct 7, 2015 02:38 PM
VoodooRacer
Feb 6, 2012 09:54 PM
cworley250sd
Feb 2, 2010 02:27 PM
Culvert
Oct 11, 2009 10:56 AM
