Stupid 4x4 question
Old Feb 5, 2012 | 11:12 PM
VoodooRacer's Avatar
VoodooRacer
Stupid 4x4 question
Do the front hubs need to be locked to have 4x4 high engage?
The reason I ask is that i went to use my 4x4 for the first time yesterday and it didnt seem to engage, as i spun the rear wheels trying to get up a steep incline. I then decided to put it in 4 low and lock the front hubs and climbed up with no problem or wheel spin. I always thought that the 4x4 high was switch on the fly auto but i could be wrong as I havent had an older 4x4 like my 01.
If this is not the case than why would the solenoids engage 4 low but not 4 high?
Thanks for the help.
Old Feb 5, 2012 | 11:19 PM
woodnthings's Avatar
woodnthings
Your hubs will engage in both high and low range. You more than likely have a vacuum leak which is keeping the hubs from auto-engaging when you select 4x4. There are a few places to look, the first is the lines from the frame to the hubs. These often rot out and won't hold vacuum. The other common spot is in the hub. also have you ever taken your auto-lock hubs apart and cleaned them?
You could also have a problem with the vacuum pump too!
Old Feb 5, 2012 | 11:20 PM
BigAlsPSD's Avatar
BigAlsPSD
I assume you have ESOF? If so they just need to be in auto, and functioning correctly with good vacuum. Does the A/C change to defrost when trying to engage?
If you have a manual transfer case(shifter on the floor) then they must be locked. As there is only a lock and off position.
Old Feb 6, 2012 | 12:16 AM
VoodooRacer
ESOF?? I didnt notice if the ac changed to defrost when trying to engage. I dont have the manual transfer case it is the dial that would be vacuum activated. I had the hubs in auto when trying to engage the 4 high but didnt seem to engage. went to neutral and switched to 4 low got out locked the hubs and 4wd worked just fine.
I will check for some leaks when i get the chance but is there a noise the system makes when locking into gear or is it fairly quite and you just have to feel the truck out to know its engaged.
Old Feb 6, 2012 | 09:05 AM
snakedoc's Avatar
snakedoc
do you have a switch in the dash for the 4X4 or a lever in the floor. if the dash (ESOF) you have a vacuum leak on the hubs, the line that goes to them. if the lever then you have to lock them in Manuel.
Old Feb 6, 2012 | 08:33 PM
KJNDIVER's Avatar
KJNDIVER
ESOF: Electronic Shift On the Fly, it is vacuum activated. You have a leak somewhere or your vacuum pump is not working. Most likely a leak. As mentioned before, the hoses from frame to hubs is one place to look. Lets hope its this, or else you have to tear down the hub assembly to change the seals. Not a bad job, just involved and not as easy as rotted hose. I just did mine a few weeks ago because of the same issue you are describing. If you lock the hubs you will have 4 high as well as 4 low. The only noise i notice is the transfer case shifting, i dont hear noise from hubs.
Old Feb 6, 2012 | 08:52 PM
cory5517's Avatar
cory5517
My hubs were shot so I bought some warn manual locking hubs and fixed my esof forever
Old Feb 6, 2012 | 09:21 PM
VoodooRacer
Ok thanks guys
Just to be clear in an emergency for the next couple days till i can fix it or get it fixed, I can manually lock the hubs up front if need be for 4 wheel drive correct?
I am taking a trip back home to louisiana on thursday and if i cant get resolved before then just want to make sure i can have 4wd to cross passes if necessary.
Old Feb 6, 2012 | 09:24 PM
BigAlsPSD's Avatar
BigAlsPSD
Yes you can manually lock the hubs, move them to lock not auto. Then your switch on the dash should engage the transfer case.
Old Feb 6, 2012 | 09:54 PM
woodnthings
Try taking your hubs apart and cleaning them per the instructions listed below.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
It may be all you need to do!
Chuck Rogers III
15
Apr 29, 2019 11:16 AM
xpl0sive
Oct 26, 2012 09:43 PM
bohiaa
Mar 5, 2009 05:17 PM
sticks25
Dec 9, 2008 06:32 PM
Seatow
19
Sep 5, 2006 07:39 PM
