Manuel transmission
Old May 29, 2018 | 02:20 PM
54truck's Avatar
54truck
Manuel transmission
Hi all I've got a c4 transmission bolted to my 289 v8. And I want to swap it for a 4 or 5 speed Manuel transmission. I'm looking for some advice on what's best to buy and swap over? Also gotta fit a clutch pedal where's best place to buy one?
Any help much apprecated
Old May 29, 2018 | 04:54 PM
jakevidrine's Avatar
jakevidrine
I mounted a T5 out of a 1999 mustang onto my 302. I had to make a new transmission mount, and get a new driveshaft... For the clutch I purchased a wildwood pedal, master, and slave cylinder and converted it to hydraulic. The clutch conversion was the biggest pain. If you have the engine out of the truck it would be much easier to set the throwout bearing distances.
There's nothing better than having that third pedal though!
Old May 30, 2018 | 11:58 AM
petemcl's Avatar
petemcl
Don't forget that you will need a pilot bushing for the end of the crankshaft. Without it the clutch will work for a little while then develop a serious vibration before destroying itself.
https://www.novak-adapt.com/catalog/pilot-bushings
Old Jun 1, 2018 | 12:10 PM
54truck's Avatar
54truck
Thanks for reply guys think I've found a box out of an early 80's mustang. It's called a toploader do you know if it will fit my 289 v8? It comes with everything to bolt on.
Vintagerestoration
Jan 21, 2019 09:55 PM
STEVE1103
Jun 24, 2018 08:35 AM
52'F-3
Sep 14, 2012 04:15 AM
48prerunner
Mar 10, 2012 11:07 PM
ccarrier
18
Jun 22, 2010 08:49 AM
