Engine Start up - Advice/Tips
Old Jun 5, 2018 | 11:29 AM
Gigemags05's Avatar
Gigemags05
The engine was mated to the transmission right after I installed the rear main seal (within a month or so). I wouldn't think it'd leak, but who knows.
I am really concerned with the milky oil up front.
Old Jun 5, 2018 | 04:40 PM
James Wagoner's Avatar
James Wagoner
Ahh okay. Clean up the leaks and do a compression test before pulling the heads I would say. Might have a leak with the intake manifold too. There is a coolant passage up front around the distributor I believe.
Old Jun 5, 2018 | 06:56 PM
Gigemags05's Avatar
Gigemags05
Well I drained the water from the radiator and it’s crystal clear. now I’m more confused.
The only place I saw the milky oil was up front where it appeared the distributor was leaking.
Im going to try and test compression tonight.
Old Jun 5, 2018 | 08:33 PM
Gigemags05's Avatar
Gigemags05
Compression readings:
Cyl 1: 119
Cyl 2: 120
Cyl 3: 118
Cyl 4: 118
Cyl 5: 120
Cyl 6: 120
Cyl 7: 120
Cyl 8: 119
I didn’t have the throttle wide open. Should I have?
Old Jun 5, 2018 | 08:44 PM
Tedster9's Avatar
Tedster9
Those look like good numbers, nice and even. They only seem low since the piston rings can't get seated till it gets on the road.
Red hot headers are most likely retarded ignition timing.
Old Jun 6, 2018 | 12:15 AM
James Wagoner
Second Tedster9's comments.
Wondering if you have a bad seal on the intake manifold somewhere in the front. Maybe the milky oil was residual from sitting? You could do another start up and see if the leak is really a leak. Unless you are certain then maybe pull the intake and inspect the gaskets and sealant. That is my only thought of where a leak around the distributor could be.
Old Jun 6, 2018 | 05:01 PM
FuzzFace2's Avatar
FuzzFace2
^^ what he said ^^
I would clean everything up front & back of intake and run it some more.
That rear main seal leak can also be the rear intake to block seal leaking. It then runs down the back of the block around the bell housing and look like it is the rear main seal. Use a mirror & a good light back there to check the intake seal.
On the AMC motors I have messed with we don't use the rubber end seals, we throw them in the trash can. When you install the intake that rubber seal gets pushed out and you then have an oil leak.
Had one do that on my drag motor, looked just like a rear main seal leak. I did not install the intake it was the way I got the motor.
Between that and maybe the front milk leak the intake may need to come off for fixing.
Dave ----
Oh what do we use to replace the rubber end seals? A bead of high temp sealer. Clean the block & intake with brake or carb cleaner, run a thick bead of sealer across the block let sit up about an hour then install the intake using the gaskets on the heads only. You may need sealer around water ports both head & intake.
When you bolt the intake down the bead of sealer should squish out a little.
Old Jun 6, 2018 | 06:05 PM
Gigemags05's Avatar
Gigemags05
Thanks for all the replies, i think y’all are on to something with the intake. I’ll clean it up and look again.
as far as the timing goes, my truck doesn’t have a pointer on it that shows where Tdc is. It was broken off sometime long ago. Wha it’s my best method to properly time it? I’ve got a light, but i have no way of really knowing where the 0 degree mark should line up. Does anyone have a picture of the timing pointer?
Old Jun 6, 2018 | 07:16 PM
FuzzFace2's Avatar
FuzzFace2
I thought the scale is part of the timing cover?
If it did break off then it bolts on no? why not et a new one then?
Now turn the motor the other way till it hits the stop and mark the balancer at the pointer.
The distance between the 2 marks on the balancer is TDC.
Some say you can use a vacuum gauge and time for the highest number.
Dave ----
Old Jun 6, 2018 | 07:31 PM
Gigemags05's Avatar
Gigemags05
Dave ----
The Pointer is definitely not there. See Pictures below:
This is from underneath looking up
This is from the top looking down
Is this what I would need? Will it just fit over what I have pictured above? I would really like to not have to replace the timing cover altogether.
https://www.ebay.com/itm/Ford-302-35...0AAOSwys5WUj18
I can't really find a good picture of the positioning of the pointer (where you read the degrees on the balancer).
Also, I am confused by the part "now turn the engine the other way until it hits the stop and mark the balancer at the pointer"
What do you mean hits the stop?
Old Jun 6, 2018 | 07:36 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
FOR FUTURE REFERENCE:::::
Rotate engine to # 1 cylinder on compression, Drop distributor in with rotor pointing to # 1 cylinder on cap, Rotate engine to the timing mark on balancer you want the timing set at I.E. 10 degrees. Then look in distributor at reluctor wheel and line the tooth on the wheel with the tooth on the distributor pickup. Lock down distributor. Timing will be at or close to what you set it at on dampner. FYI been told one half of a tooth off on reluctor is @ 7 degrees. (never checked this fact)
If you set distributor this way it will be super close to perfect.
Other start up tips.
Always prelube. Was always told to use a straight 30 weight oil for break-in.
I always use water in radiator till after break-in, That way if you have a leak or blow a hose, doesn't loose all that expensive antifreeze.
If engine runs hot put a box fan in front of radiator.
When you get to drive it, get on highway and run up speed and let it coast down in each gear a couple of times, This will help seat the rings. Have seen some chrome rings go 5000 miles before it quit using oil.
Check oil every day you drive to keep check on oil level.
After 500 miles change oil.
After break-in, drive truck like you stole it. Or just drive it like you are going to use it.
Old Jun 6, 2018 | 07:45 PM
Gigemags05's Avatar
Gigemags05
Moose,
I did all of that (as far as setting the timing), but I am not able to confirm where the 10 or 0 marks on the balancer should be because I do not have the timing pointer.
as for the rest of it, i appreciate the pointers. I’ll take that into account when i finally get this old boat moving.
Old Jun 6, 2018 | 09:08 PM
  #28
moose4x4's Avatar
moose4x4
FTE Emeritus
Originally Posted by Gigemags05
Moose,
Would be harder without a pointer for sure. You might need a vacuum gauge then to set timing, hook to manifold vacuum start engine advance distributor to get highest vacuum reading and back off 1 lb vacuum. Lock distributor down. Should be close.
Old Jun 6, 2018 | 09:12 PM
  #29
Gigemags05's Avatar
Gigemags05
Ok thanks. That is a good idea.
jeffshep150
Jan 26, 2013 05:46 PM
SparkyRnD
25
Feb 19, 2012 08:26 AM
351beast
Dec 3, 2006 11:55 PM
eandaauto
Aug 6, 2004 12:43 PM
Shredit
Jun 24, 2004 07:05 PM
