Teach the kid!
Old Dec 2, 2006 | 08:18 PM
351beast's Avatar
351beast
Teach the kid!
okay yall, going with the short intro im a 17 y/o kid learning to work on cars.
now i've been able to diagnose on my own that my 351m has an ignition timing issue (backfires out of the carb) and i've been trying to learn how to time it on the internet caues my old man is out of town, no go cause it only tells me how to time it if it is running. i need to know how to time it without it being turned on (if u havent guessed it wont start)
now i've been reading up as much as i can, i know that the distributor goes counter clockwise, heres what im gonna guess. starting at cylinder 1 it should go 1 3 7 2 6 5 4 8 around the distributor. thats just a guess. if i am wrong please correct me
so the 2 questions are
how do i set up the ignition timing (351M)
how to the plug wires go according to cylinder on the distributor
Old Dec 2, 2006 | 09:48 PM
danlee's Avatar
danlee
Set the timing pointer to 0 degrees when the piston in #1 cylinder is at TDC on the compression stroke. You can tel that it is on the compresion stroke when both valves are closed, or when there is pressure at the spark plug hole.
At this point the rotor in the distributor should point to #1 plug wire terminal. There may be a 1 on the cap at this terminal.
Rotate the motor by hand two complete revolutions in the direction of rotation. The rotor should now point to #3 plug wire terminal.
Connect the remaining plug wires as per the firing order.
Connect the timing light and attempt to start it. If it doesn't start Check the timing while it is cranking with the vacuum advance line removed from the distributor and plugged, and set it per specification.
Before you go through all this trouble, ask yourself 'How did it get so far out of time that it won't start?' You could have a stretched timing chain, or jumped a tooth on the timing gear.
Look up on the internet 'How to check for a stretched timing chain'.
Old Dec 3, 2006 | 03:58 PM
grclark351's Avatar
grclark351
"Rotate the motor by hand two complete revolutions in the direction of rotation. The rotor should now point to #3 plug wire terminal."
HOLD THAT! if you rotate the crank 2 full turns you'll be right back at #1 TDC, but it is good to check after dropping the dizzy in.
if you rotate the crank 90* from #1 TDC, you'll be at #3 TDC. another 90* will get you to #7 TDC, and so on, and so on.
http://www.supermotors.net/getfile/4...gordercard.jpg
cylinders 1234 are on the US passenger side, cylinders 5678 are on the US drivers side. it's not a chevy.
i agree with Danlee, you need to ask yourself why it got this way. could be the pin that holds the distributor gear is damaged and the distributor is out of time with the engine, it happens a lot. if it is, you need to make sure that the oil pump is still able to turn freely. a 5/16 socket fits on the oil pump driveshaft. counterclockwise should build pressure, clockwise should make bubbles. if it doesn't turn, uh oh.
Old Dec 3, 2006 | 06:27 PM
danlee's Avatar
danlee
OOOPS, My bad! It must have been late.
Old Dec 3, 2006 | 07:04 PM
351beast's Avatar
351beast
skipped a tooth on the timing chain.
this old truck is turning out to be more of a burden than a joy.
Old Dec 3, 2006 | 08:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
The OEM timing chain needs to be changed at 80K miles. I have seen them fail any time after that. Replace it with an aftermarket roller chain setup so you can reset the cam timing to straight up or "0" on the new timing sprocket.
Old trucks are OLD and need lots of TLC!
Old Dec 3, 2006 | 09:27 PM
VirginiaWiFinder's Avatar
VirginiaWiFinder
Here are two tips....
1. To better see the timing line, fill in the groove with white out. It makes it a ton easier to see when the strobe form the gun is flashing. (Light flashes as spark passes through the wire)
2. To turn the motor a bit easier by hand (and without causing the truck to backfire) remove the spark plugs. No compression = much easier to turn. If the plug wires are installed be careful where the end goes. Don't want any nasty arcs into something flamable or a boot getting caught in a belt.
Old Dec 3, 2006 | 09:28 PM
351beast's Avatar
351beast
i know old trucks need alot of tlc
but
A $1000 car ain't even gonna roll,
til you throw at least another thousand in the hole.
Sink your money in it, and there you are
the owner of a 2,000 dollar 1,000 dollar car.
good song right there
but, i will keep throwing money at it!!!!....i also need to learn how to change a timing chain
Old Dec 3, 2006 | 11:51 PM
grclark351's Avatar
grclark351
do you have the front cover off and you have visually confirmed that the timing chain has skipped?
or are you looking at the rotor pointing to the wrong position? could still be the dizzy gear pin. easier than a timing chain.
Old Dec 3, 2006 | 11:55 PM
351beast's Avatar
351beast
cover off, i got frustrated enough after i did the ignition timing that i just started pulling it all apart
