Locking differentials questions.
Old May 27, 2018 | 01:17 PM
1999-F150's Avatar
1999-F150
Hey guys I hope you are having a fantastic weekend. I was just wondering about locking center differentials. From what I have read the front and rear diffs are open right? Is the center diff locked and only locked in 4h and 4l? Or is it even locked at all?
Thanks
2006 explorer 4x4 4.0 160k
Old May 27, 2018 | 06:34 PM
steve(ill)'s Avatar
steve(ill)
Factory units don't "LOCK"... they are called LIMIT SLIP.......... there is a clutch pack tieing the left and right axle halfs together. They will drive together from the pinion, but can "slip" if needed to go around a corner. Normally you get a LS unit in the BACK, and the front end is not.
Old May 27, 2018 | 06:59 PM
1999-F150's Avatar
1999-F150
Thanks for the reply. What about the center diff?
Old May 27, 2018 | 07:01 PM
ford390gashog's Avatar
ford390gashog
What center diff? There is no center differential.
Old May 27, 2018 | 08:42 PM
1999-F150's Avatar
1999-F150
Transfer case
Old May 28, 2018 | 08:25 AM
steve(ill)'s Avatar
steve(ill)
The transfer case, when engaged, puts power to the front and back driveshafts. It is a mechanical drive so "theoretically" you could say it is LOCKED. You get power to the front and back.... If the back tires are stuck in the mud and spinning, the front tires will continue to turn and pull thru.
Old May 28, 2018 | 09:30 AM
1999-F150's Avatar
1999-F150
Thank you!
Old May 28, 2018 | 05:05 PM
00t444e's Avatar
00t444e
Don't some Explorers have AWD or full time 4x4? If your transfer case has 2wd, 4x4 high, and 4x4 low then it is a part time only transfer case that locks the front and rear axles together when in 4x4, however if it has AWD or full time 4x4 it does have a center differential in the transfer case, and you can run full time 4x4 all the time if you want to but it will use more fuel.
badasssapper67
Mar 26, 2016 07:24 AM
96_F250_Deezal
Feb 5, 2012 11:06 PM
thebeastof1980
Feb 13, 2008 09:49 AM
yukonsly
Feb 20, 2007 07:38 PM
jwtaylor
Sep 10, 2001 08:05 AM
