Sponsored by: Real Truck
rear diff limited slip
Old Feb 13, 2008 | 01:48 AM
thebeastof1980's Avatar
thebeastof1980
Cool rear diff limited slip
Has anyone replaced the clutch packs in a ford 10.25 rear diff limited slip unit. I am trying to figure out how to get those darn things out. im guessing there is a special tool to relieve the tension so you can pull out the spider gears, im stumpped.I need this done tonight if any one knows or knows where i can get info on the web greatley appreciated.
Old Feb 13, 2008 | 07:09 AM
F350-6's Avatar
F350-6
Is it a 1 piece or 2 piece traction lock. My manual lists options for both under the 10.5 rear diff.
Old Feb 13, 2008 | 07:47 AM
thebeastof1980
limited slip
It has two clutch packs for left and right. the center is open. not sure what they cal it
Old Feb 13, 2008 | 09:48 AM
F350-6's Avatar
F350-6
Looks like you do need the special tool.
Here's the instructions on the 1 piece
File Type: pdf
File Type: pdf
Old Feb 13, 2008 | 09:49 AM
F350-6's Avatar
F350-6
And here's the instructions on the 2 piece.
Hope this helps.
File Type: pdf
File Type: pdf
