New Project 65 F100
It's a WINDSOR. Notice the upper rad hose/thermostat housing coming directly off the Intake Manifold??
On a Cleavland, the thermostat housing is vertical, and attached directly to the block.......
AND the Valve Covers/heads on a Cleavland are considerably different, you'll know one when you see one
Day 1: Dissassembly
Here are before pics as it sat this morning. Need to widen the wood bed a board or two. Figure out what to do in the engine bay (I hate flat black)...? Pull the motor and transmission to go over them. Try to make some extra ponies from this ole 302. Re clear/polish the patina. Do something with the seat probably re foam and cover it. Undercoat the cab, paint the frame. Upgrade the brakes with either front disks or just a booster/master upgrade. Contemplate power steering. Also contemplate putting a trac loc in the 9”. And fix some smalls like leaking rear axle seal, ebrake, reverse lights, and window seals. I need help and suggestions tho I don’t have any manuals or help just me and my tools
Max Mcglasson
50
09-11-2018 03:19 PM
apso1857
11-14-2017 08:34 PM
pinkcamo007
08-13-2014 03:03 PM
