New Project 65 F100
Hey guys hoping to get some help with my build. Truck is a 65 and could use some help |
Originally Posted by rustylightning
(Post 18005231)
https://cimg0.ibsrv.net/gimg/www.for...4ea6b299b.jpeg Hey guys hoping to get some help with my build. Truck is a 65 and could use some help deciphering vin, original paint code, engine tranny rear end etc. have had luck in the past on here so gonna post up some pics and see what you guys think If this truck has a 240 or 300 I-6, the hood emblem is correct. If it has the 352 2V, it's not. The stake bed is aftermarket as are the wheels and the radio antenna. Post a pic of the Warranty Plate, riveted to the left door face below the latch. |
(Post 18005334)
Right fender emblem is 1965, but the painted steel grille is from a 1966.
If this truck has a 240 or 300 I-6, the hood emblem is correct. If it has the 352 2V, it's not. The stake bed is aftermarket as are the wheels and the radio antenna. Post a pic of the Warranty Plate, riveted to the left door face below the latch. Great thank you. Here’s the warranty plate. |
The vin is: F10JE626390 |
Numberdummy I’ve read that later 65’s came with that grille not sure if you can confirm that |
(Post 18005372)
F10 = F100 2WD J = 240 1V I-6. E = Mahwah NJ Assembly Plant. 626390 = 1965. 115" Wheelbase. COLOR: O = Peacock Blue. MODEL: F100 = F100 2WD, 5,000 lbs. GVWR BODY: ?81: ? / 81 = 81A Standard Cab. TRANS: A = Ford type 3.03 3 Speed Manual all Synchromesh Transmission. AXLE: 08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Axle Capacity. MAX GVW LBS: 5,000 lbs. Gross Vehicle Weight Rating. CERT NET HP 129 @ 4,000 RPM DSO: ? No 1965 came with a 1966 grille from the factory. 1965 production ended the first week of August. September 1965: Ford obsoleted the 1965 grilles, replaced them with 1966 grilles for use as "service part replacements." |
You the man! You’ve helped me before. If I post pics of the engine and transmission can you help me figure out the years/type? They have been swapped |
(Post 18005417)
If I post pics of the engine and transmission, can you help me figure out the years/type? They have been swapped Post them and I'll see, but I kinda doubt I'll be able to ID the size of the engine. The trans may also be a PITA to ID |
https://cimg2.ibsrv.net/gimg/www.for...a103a70c1.jpeg https://cimg3.ibsrv.net/gimg/www.for...a65d5e18f.jpeg https://cimg5.ibsrv.net/gimg/www.for...9124e4db4.jpeg https://cimg4.ibsrv.net/gimg/www.for...fc0a9ab6b.jpeg https://cimg6.ibsrv.net/gimg/www.for...76d7017a1.jpeg https://cimg9.ibsrv.net/gimg/www.for...a0a0978c2.jpeg
(Post 18005430)
i can can look for codes or whatever it takes to identify if you point me in the right direction here are pics to get started |
The valve covers have been painted, not sure what the 73 on inner fender wall is, and added a pic of rear axle to confirm it’s the 9” I’ve read the 9” are a very good axle? |
(Post 18005436)
The valve covers have been painted, not sure what the 73 on inner fender wall is, and added a pic of rear axle to confirm it’s the 9” I’ve read the 9” are a very good axle? Dizzy cap with male ends introduced in 1977. How many valve cover bolt holes per side? The carb is a Motorcraft 2150 series 2V, introduced in 1975. It's probably original to the engine. Trans is an A/T .. How many trans pan bolt holes does it have (could be 11 or 17)? |
(Post 18005456)
I'm no expert but looking at the pictures it looks to be a 302 and a C4.
Originally Posted by 53deere
(Post 18005501)
I'm no expert but looking at the pictures it looks to be a 302 (6 valve cover bolts) and a C4 (11 trans pan bolts).
