New Project 65 F100 - Ford Truck Enthusiasts Forums
New Project 65 F100
Old 05-27-2018, 09:57 AM
rustylightning
rustylightning is offline
rustylightning is starting off with a positive reputation.
New Project 65 F100
Hey guys hoping to get some help with my build. Truck is a 65 and could use some help
Old 05-27-2018, 11:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by rustylightning View Post
Hey guys hoping to get some help with my build. Truck is a 65 and could use some help deciphering vin, original paint code, engine tranny rear end etc. have had luck in the past on here so gonna post up some pics and see what you guys think
Right fender emblem is 1965, but the painted steel grille is from a 1966.
If this truck has a 240 or 300 I-6, the hood emblem is correct. If it has the 352 2V, it's not.
The stake bed is aftermarket as are the wheels and the radio antenna.
Post a pic of the Warranty Plate, riveted to the left door face below the latch.
Old 05-27-2018, 11:27 AM
rustylightning
Great thank you. Hereís the warranty plate.
Old 05-27-2018, 11:28 AM
rustylightning
Old 05-27-2018, 11:29 AM
rustylightning
The vin is: F10JE626390
Old 05-27-2018, 11:47 AM
rustylightning
Numberdummy Iíve read that later 65ís came with that grille not sure if you can confirm that
Old 05-27-2018, 11:56 AM
NumberDummy
Most of this I can read, the 1st digit of the BODY code and the DSO code, I cannot make out. Posting the VIN (F10JE626390) was a big help.
F10 = F100 2WD
J = 240 1V I-6.
E = Mahwah NJ Assembly Plant.
626390 = 1965.
115" Wheelbase.
COLOR: O = Peacock Blue.
MODEL: F100 = F100 2WD, 5,000 lbs. GVWR
BODY: ?81: ? / 81 = 81A Standard Cab.
TRANS: A = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
AXLE: 08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Axle Capacity.
MAX GVW LBS: 5,000 lbs. Gross Vehicle Weight Rating.
CERT NET HP 129 @ 4,000 RPM
DSO: ?
No 1965 came with a 1966 grille from the factory. 1965 production ended the first week of August.
September 1965: Ford obsoleted the 1965 grilles, replaced them with 1966 grilles for use as "service part replacements."
Old 05-27-2018, 11:58 AM
rustylightning
You the man! Youíve helped me before. If I post pics of the engine and transmission can you help me figure out the years/type? They have been swapped
Old 05-27-2018, 12:06 PM
NumberDummy
If I post pics of the engine and transmission, can you help me figure out the years/type? They have been swapped
Post them and I'll see, but I kinda doubt I'll be able to ID the size of the engine. The trans may also be a PITA to ID
Old 05-27-2018, 12:09 PM
rustylightning
i can can look for codes or whatever it takes to identify if you point me in the right direction here are pics to get started
Old 05-27-2018, 12:12 PM
rustylightning
The valve covers have been painted, not sure what the 73 on inner fender wall is, and added a pic of rear axle to confirm itís the 9Ē Iíve read the 9Ē are a very good axle?
Old 05-27-2018, 12:40 PM
NumberDummy
The valve covers have been painted, not sure what the 73 on inner fender wall is, and added a pic of rear axle to confirm it’s the 9” I’ve read the 9” are a very good axle?
Dizzy cap with male ends introduced in 1977. How many valve cover bolt holes per side? The carb is a Motorcraft 2150 series 2V, introduced in 1975. It's probably original to the engine.
Trans is an A/T .. How many trans pan bolt holes does it have (could be 11 or 17)?
Old 05-27-2018, 01:01 PM
rustylightning
It has 6 valve cover bolts and 11 trans pan bolts
Old 05-27-2018, 01:21 PM
53deere's Avatar
53deere
53deere is offline
53deere is starting off with a positive reputation.
I'm no expert but looking at the pictures it looks to be a 302 and a C4.
Old 05-27-2018, 02:10 PM
NumberDummy
Originally Posted by 53deere View Post
I'm no expert but looking at the pictures it looks to be a 302 (6 valve cover bolts) and a C4 (11 trans pan bolts).
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
