1978 - 1996 Big Bronco
IAT Sensor (Need Help ASAP)
Old May 27, 2018 | 02:42 AM
Mr.TankBronco's Avatar
Mr.TankBronco
Exclamation IAT Sensor (Need Help ASAP)
I have a code being thrown P0113 (IAT Sensor) I have checked the IAT sensor, replaced it twice, checked the plug to ensure it's doing it job creating resistance based off temperature, checked fuses, installed a new MAF, I am so lost on how to get this code to stop throwing. I need help ASAP I have a wedding to attend up in Colorado and I need the truck to keep my mixture right so its an easier trip to Colorado. I also need this so I can get the damn thing plated for the drive otherwise I'm screwed. Please help ASAP. I have talked with a few people none of which are helpful at all. Help me (I'm losing my mind)
Truck Info: 1996 Bronco XL 5.0 V8
Old May 27, 2018 | 10:35 PM
ZombieSlayer's Avatar
ZombieSlayer
A lot of people overlook the air filter and air filter box when messing with MAF/IAT problems. A dirty filter or blocked duct can cause you problems since they are both upstream of the sensors. Make sure the filter box is properly closed and secured as well.
Old Jul 28, 2018 | 12:20 AM
vjsimone's Avatar
vjsimone
Are you buying motorcraft parts ?
Old Jul 30, 2018 | 10:04 AM
rla2005's Avatar
rla2005
Is that code from Continuous Memory? If so, you need to clear the codes before re-running the code check. Even after replacing the part the stored codes will not clear until you have driven 60-80 drive cycles (maybe 40?) or manually cleared them.
mzcp pumping
6.7L Power Stroke Diesel
Apr 2, 2019 03:20 PM
boatnfish
2009 - 2014 F150
Aug 26, 2015 06:01 PM
prerunnerswag98
6.4L Power Stroke Diesel
18
Oct 2, 2012 08:11 PM
srgpelayo
1997 - 2003 F150
Mar 23, 2011 10:02 PM
jjfl99psd4x4
Oct 18, 2005 12:35 AM
