code po113
Old Oct 17, 2005 | 11:34 PM
jjfl99psd4x4's Avatar
jjfl99psd4x4
code po113
I have a early 99 psd. I scanned the codes tonight just for the hell of it and came up with code P0113. I did a forum search and came up with Air Intake Temp sensor??? The crappy old air filter has been replaced in this truck with a open air type filter. This filter is just setting in the old filter box with the box lid removed. What does this sensor do, and what if any performance am I missing with this code being on. The truck seems to run fine ( as good as any truck with 190000 miles does )
Any and all help is much appreciated......
By the way, when I try to clear the code, It does not seem to go away. I am using a tuner to read the code. It asks me if I want to clear the code, I say yes...It says it is clearing the code, but when I re-scan it it is still there. I have not started the truck again.....Am I missing something?
Old Oct 17, 2005 | 11:40 PM
Kwikkordead's Avatar
Kwikkordead
Still have the old sensor? Plug it back in and zip tie it to a brake line.
Old Oct 17, 2005 | 11:50 PM
jjfl99psd4x4
I may have it, but not sure... Where would it need to be mounted, and do you have any idea what it does?
Old Oct 18, 2005 | 12:04 AM
SpringerPop's Avatar
SpringerPop
It's probably still in your old air box. It comes out with a quarter-turn. Plug it back in and the code can be cleared. Zip-tie it to anything so it doesn't flop around and get broken. It doesn't matter where you put it. Just secure it.
It measures inlet air temperature to your turbo.
Pop
Old Oct 18, 2005 | 12:35 AM
jjfl99psd4x4
OK... With the code on, would this affect anything ??? would the truck run any different if the sensor were working
Great Danes
6.7L Power Stroke Diesel
Feb 29, 2012 05:29 PM
slomoe1
1983 - 2012 Ranger & B-Series
Jun 6, 2008 07:01 PM
zman764
1997 - 2003 F150
Nov 8, 2007 07:57 PM
jjfl99psd4x4
Nov 29, 2005 09:11 AM
vicv
24
Jul 4, 2005 09:55 AM
