Pll02 code and P0402 code
Old Apr 1, 2019 | 03:07 PM
mzcp pumping's Avatar
mzcp pumping
7th Gear
I just got the truck back from dealer for a recall for oil separator sensor and now it threw code p0113 so I bought a new air filter and cleaned the IAT sensor and now it thre codes pll02 and p0402 and po4da does anyone have any suggestions it's a 2014 f250 6.7 thanks
Old Apr 1, 2019 | 04:35 PM
Just Strokin's Avatar
Just Strokin
The codes deal with MAF and EGR. Maybe they didn't plug up all the connectors? I would go back to the dealer and have them recheck their work.
P1102 – Mass Air Flow Sensor In Range But Lower Than Expected
Old Apr 1, 2019 | 06:32 PM
mzcp pumping
7th Gear
2014 ford 6.7 P0113
How to fix this plugged in truck and code P0113 came up replaced air filter and cleaned the sensor . Now engine lite came back on and codes P1102 and P0402 came on .should I replace the sensor?
Old Apr 1, 2019 | 07:58 PM
Just Strokin
Did you have these codes before the dealer did the recall for the CCV? If the answer is no, then I would go back to the dealer and have them check their work.
Still think there might be some sensors unplugged.
Old Apr 2, 2019 | 03:20 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Definitely take it back to the dealer if the codes are new. As soon as you start messing around with repairing their problem, you take a chance of it becoming your problem.
TrueBlue02
Nov 16, 2015 05:07 PM
stevenjf88
Jun 16, 2015 08:03 PM
mhamrick56
Feb 22, 2010 12:12 PM
SadButTrue
Apr 30, 2000 11:38 AM
