A smoother ride
Old May 26, 2018 | 06:36 PM
jimzpsd's Avatar
jimzpsd
A smoother ride
I installed my ReadyLift 2.5" leveling kit today and I had already replaced the factory shocks with Fox 2.0's (about a year ago). And when I installed the kit, I chose not to install the longer shock mounts. . The truck now rides like a car, no kidding. Even the wife commented on the improvement on roads that would knock us around prior. By allowing the Fox shock's piston to settle/ride in the center of the damper tube (instead of the top third), I truly think this is the reason for the improvement.
Old May 26, 2018 | 11:37 PM
Tricon's Avatar
Tricon
Did you have the wrong shocks off the bat? Maybe you have the 2.5" lift versions?
Old May 27, 2018 | 01:26 AM
Toledo's Avatar
Toledo
did you get the leveling kit with the trac bar relocation bracket? part numbers for everything
Old May 27, 2018 | 07:54 AM
jimzpsd's Avatar
jimzpsd
Those are my thoughts too, because when I installed them (Fox) there was only about 3" of the chrome rod visible and the ride was not that much better than stock. But now you can clearly see more rod exposed, assuming thats normal and the piston is "in the oil" where it should be.
I bought the Fox shock when all of us were, so maybe I got the wrong ones, idk.......sure loving it now. The rear shocks look normal, but I always questioned the fronts.
Old May 27, 2018 | 07:57 AM
jimzpsd's Avatar
jimzpsd
https://www.ebay.com/itm/ReadyLIFT-2...IAAOSwAaJaDGlw
Old May 27, 2018 | 03:52 PM
honda250xtitan's Avatar
honda250xtitan
it was constantly bottoming out is what it sounds like. surprised those shocks didn't blow out.
Old May 27, 2018 | 05:57 PM
jimzpsd's Avatar
jimzpsd
Why do you say that, it never bottomed out in my opinion. The piston was always at the top of the reservoir and I don't think it was ever in the hydraulic fluid. Truck is only street driven.
gtnwood
Jan 14, 2011 11:00 AM
saltamontes
Mar 3, 2009 03:43 PM
Little General
2004 - 2008 F150
Oct 29, 2007 11:30 PM
45_70lx0780
Mar 29, 2006 07:09 PM
BroncoMTR
Offroad & 4x4
Mar 3, 2004 07:38 AM
