Offroad & 4x4
Leveling kit and shocks
Old Feb 29, 2004 | 02:29 PM
BroncoMTR's Avatar
BroncoMTR
I have a fairly new set of Ranchos on my truck, and am about to put a 1.5 leveling kit on it. I know it will be allright will the stock size shocks, but I want to know if it has any significant drawbacks. Will downward suspension travel be limited? Will I not notice the difference? What have you guys with the kits done?
Old Feb 29, 2004 | 02:37 PM
BroncoMTR's Avatar
BroncoMTR
I'm also debating whether to put an add-a leaf or blocks in the rear. I'm fairly new to the scene and have never done either, although both look pretty easy to do. Suggestions?
Old Feb 29, 2004 | 07:29 PM
WhëëlMå1's Avatar
WhëëlMå1
Most manufacturers state that you can retain youre stock shocks with a 1.5" leveling kit. When I put a 1.5" on my truck, the shocks didnt last. But to be fair, the truck had 58k on it, and they appeared to be the shocks from the factory. I plan on purchasing new shocks soon. Unless you really thrash youre bronco, I dont think you will have too many problems. If you like hopping logs and rocks, I dont see those shocks lasting from exactly what you mentioned...restricted downward travel. Any reason you want to lift the truck up in the rear? I love the way mine sits level.
Rich
Old Feb 29, 2004 | 10:55 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You can put limiter straps on it to keep from overextending your shocks. They sell them at most 4wd shops and if you can weld, just weld up some tabs to mount them to.
Old Mar 1, 2004 | 09:30 AM
85351ho's Avatar
85351ho
they will probabl sllightly limit droop
Old Mar 2, 2004 | 10:02 AM
wick246's Avatar
wick246
I am about to add 1.5" springs on my '95 as well but I can't find many shocks for only 1.5" of lift. I was hoping on using Bilstiens but they seem to only have stock ride hieght and 4"+ lift shocks.
Old Mar 2, 2004 | 05:53 PM
BroncoMTR's Avatar
BroncoMTR
There will be some log hopping and suspension travel. Not everyday, but it can fairly often, namely if they open up all the trails they closed down here. I want to lift the rear of the truck an 1 inch or so, because I drive every now and then I have a decent load, and I think the the back would squat to much in comparision. Also, with careful guidance I have little problems hitting the front bumper, but the rear is another story. More than once I've smacked it down onto a rock or bump. I better approach angle in the rear would be helpful. Plus, I don't mind the front sitting an 1 lower, it'll look even when I'm driving a full load of people anyhow. Anyone have an opinion on 1 1\2 rear lift? How is the ride quality of blocks verses add-a-leaf, and ease of installation?
Old Mar 2, 2004 | 06:02 PM
WhëëlMå1's Avatar
WhëëlMå1
Blocks are unsafe, not matter how you cut it. Under stress(i.e. offroad), they can be spit out from below the leafs. Sound like something you want to deal with? They will probably ride nicer on road due to the fact that you arent changing the leaf return rate. They do not increase youre load carrying capacity like the add a leafs do. For the money, I would go for the extra leaf.
Rich
Old Mar 3, 2004 | 01:34 AM
SoCalDesertRider
I agree, the springs would be better than blocks in the rear. But, that being said, my truck came straight from the factory with lift blocks in the rear, as did thousands of other Ford trucks, and even most of the new trucks have them. So far I haven't noticed a rash of trucks sitting on the side of the road with broke down rear axles from blocks flying out...
Old Mar 3, 2004 | 07:29 AM
WhëëlMå1's Avatar
WhëëlMå1
The stock blocks are different. They are relatively small. The aftermarket blocks are much larger, and as a result, more force is applied to them laterally when offroading.
Rich
Old Mar 3, 2004 | 07:38 AM
fishmanndotcom's Avatar
fishmanndotcom
i guess you didn't realize that f350s come stock with 3" blocks in the rear! the new ones do and i know for a fact that they were used heavily in the 70's. blocks are not ever gonna be spit out! it would be really hard. the problem with blocks is there is more leverage for the axle to twist and posibly snap something! I agree, i hate blocks too, but they aren't as problematic as most think!
If you are looking to remove your rear blocks AND gain 1-2" lift from factory do a shackle flipped rear! I did and I love it!
You stock shocks will be more than enough for just a 1-1.5" lift. I could use stock shocks on my 6" lift but they would limit my flex a lil!
-jason-
