I need some help picking the correct leaf springs to level the truck. I have a two leaf spring now not working 7.3 to heavy
has anybody done this if so what leaf pack of lift did u use rear wheel well is 39.5"front is 36" thanks for your help
1995 f250 7.3 powerstroke xlt extra cab 5 speed
Ok got it thanks it's Q4A so what does that say about my truck
You have the heaviest rated spring Ford offered in those years. We offer a direct replacement option that will net you 2" over factory height but you will need to address the alignment after the install. Because of your front axle these trucks can be a real pain to align when you lift the front end up. You will most likely need to get pivot brackets that will accommodate the higher stance of the truck in the front.
Ok I see well I was looking at your site y'all have 43-498HD is this the spring your talking bout looks the same but it's 3 leafs. I've done camber sleeves what it the brackets your talking bout or will the 3 leaf spring feel like a wagon lol
The 3 leaf will give you some lift but it will definitely firm up the ride. We usually sell those springs to customers who have plows, heavy bumpers/winches or a combination.
