I've got a 74 f250 4x4 that I'm doing the 99-04 super duty gas 8" BDS front springs conversion to or at least I'm going to attempt to but when I'm looking for the springs I need I keep running into people talking about the spring cose, so which spring code do you think would be best? And are the 8" BDS stock on the 99-04 ford super duty or is that an after market lift spring for that year truck?
I believe the spring code is a letter that applies to specific applications of leaf spring ability or application determined by GVW? And no the 8" BDS leaf spring is NOT STOCK by no means.
" got a set of SD springs from the junk yard and added my bottom stock leaf to them. Had to get me 4" or so. Add-a-leafs will ride terrible. For the rear, just flip the shackle, that will net you around 3" and will sit the truck a little more level. I spent $45 a spring pack for the SD springs, so I had a 4" lift under $100. Oh, I suggest making some front shackles 1-2" longer than stock, as the SD are around 1" longer, so they could bottom out on the frame. All in all the whole setup should get you 3-5" and a level truck. If the front sits too high you could also get F-350 rear blocks, they are 4" instead of the 2" that are in F-150 and F-250."
