Ignition problems...
Old May 25, 2018 | 11:52 AM
444fan's Avatar
444fan
I got a 97 f250 powerstroke with the 5spd. I can't start the truck through the key, a mechanic put on a push button start. No clicking or noise when I turn to cranking. I've replaced the parts from the steering wheel to the fender starter relay. Anyone else experience this or have a fix?
Old May 25, 2018 | 08:55 PM
Mudsport96's Avatar
Mudsport96
Well of you have done the column wiring and underhood wiring, did you replace the clutch switch? That can cause a no start as well.
Old May 26, 2018 | 06:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could be a bad clutch safety switch, bad clutch pedal bushing, bad ignition switch, bad ignition actuator, ignition switch out of alignment to name a few issues that would cause it not to start with the key. anyone that would put in a push button as a "repair" is not a mechanic.
Old May 26, 2018 | 07:14 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by tjc transport
....anyone that would put in a push button as a "repair" is not a mechanic.
That’s exactly was thinking. More of a hack.
Old May 26, 2018 | 07:57 AM
444fan's Avatar
444fan
Where would that be located?, under the column near the pedals?
Old May 26, 2018 | 08:22 AM
tjc transport
i ain't rite
not sure where the ignition switch is on the 92 and newer trucks, never did one of them. the clutch interrupter switch is on the pedal assembly
Old May 26, 2018 | 09:21 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
You should be able to find something to help you at the other end of this link:
1994 Ford Crown Victoria Steering Column pictures, videos, and sounds | SuperMotors.net
Old May 27, 2018 | 09:02 AM
444fan's Avatar
444fan
Hardscrabble, thanks for the link and pics. Edit, I've pulled the ignition switch before, nothing appeared burnt or distorted...I'll try the continuity test later today.
Old Jul 12, 2018 | 06:36 AM
444fan's Avatar
444fan
Update. Swapping out the clutch interrupter switch didn't do anything. Trying to Ohm my way around didn't result in any issues unless I did that wrong.
Thought I'd update this to close this page, I don't like see them questions with no answers or fixes. Thanks for the help folks.
AlexCa
Sep 27, 2017 01:20 PM
loganmick
16
Jul 11, 2015 05:09 PM
97 STILL STROKIN
Feb 16, 2012 03:31 PM
tarzanstree
Mar 22, 2011 02:11 PM
SealAnubis
Dec 29, 2006 04:05 PM
