Clutch interlock safety switch?
Old Mar 22, 2011 | 11:34 AM
tarzanstree's Avatar
tarzanstree
New guy here....I am having trouble locating the CIS on my 1990 f250 4X4? I pulled the panel off under the steering wheel and shined a light up there and could not find any kind of switch...all is see it the arm, the bumpers for when it is pressed and when it comes back, and the spring that pulls it back...description of location or diagram? Thanks a bunch!
Cody
Old Mar 22, 2011 | 12:05 PM
tarzanstree
Never mind...finally found it...Thanks anyhow!
Old Mar 22, 2011 | 12:36 PM
tarzanstree
Pickup is not starting, at ignition, but it does when I jump the solenoid...what is the easiest way to rule out the Clutch interlock safety or the ignition?
Old Mar 22, 2011 | 01:12 PM
jas88's Avatar
jas88
You can jump the clutch switch and if it still won't start, pull the ignition switch off the top of the steering column and move it manually with a screwdriver. If it starts this way, I suspect your ignition acutator is broken and so it's not pressing the rod down far enough to activate the ignition switch all the way.
Old Mar 22, 2011 | 01:19 PM
tarzanstree
Sorry, but I do not know how to jump the clutch switch? Could you please explain? Thanks
Old Mar 22, 2011 | 02:08 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...ty-switch.html Have a read here.
Old Mar 22, 2011 | 02:11 PM
jas88's Avatar
jas88
Ford used a jumper on automatic transmission equipped trucks so that the wiring harness would be the same. If you can locate one of those, you just plug it in place of your clutch switch. Otherwise you gotta use a jumper wire as the linked thread suggests.
chewyacura
Jul 1, 2013 08:03 AM
Ford59galaxie
Nov 20, 2012 01:05 AM
senix
Apr 8, 2010 01:03 PM
wild_bill_71
Jan 25, 2006 07:55 PM
hoganlo
Feb 25, 2004 02:21 PM
