6.0 powerstroke
Old May 24, 2018 | 08:32 PM
Jadenhughz's Avatar
Jadenhughz
6.0 powerstroke
I replace #2 injector and the truck ran before i took it apart i put it back together now it just crank and cranks but wont fire .can anybody help me
Old May 24, 2018 | 08:56 PM
mattdoc88's Avatar
mattdoc88
What's your ICP, IPR %, and rpm during cranking?
Old May 25, 2018 | 05:33 AM
53jimc's Avatar
53jimc
I had the same issue a couple months back. Replaced an injector, got it all back together, no start, it wasn't building high pressure oil. Did a leak test and nipple seals were leaking. Replaced all of those and it fired right up. It would probably be good to do an air test on it.
Old May 25, 2018 | 08:20 AM
bismic's Avatar
bismic
Did you oil up the injectors and ball tubes before re-installing the oil rail?
Old May 25, 2018 | 08:44 AM
53jimc's Avatar
53jimc
I did. The old ones were a bit loose in the socket when I installed the rails after the injector replacement. I really didn't pay it any attention, so I got to do it all over again. Bought the seals and a socket, removed them with an impact wrench, installed nipples with a torque wrench, greased 'em up good on install.
davida7777
Feb 1, 2019 08:48 PM
BRIAN NORCAL
Jul 17, 2018 08:36 AM
cookingguy
Feb 1, 2016 08:51 AM
crwcmechanic
Aug 1, 2014 03:54 PM
Gmangh15
Nov 28, 2011 08:24 PM
