6.0 injectors
Old Nov 18, 2011 | 12:11 PM
Gmangh15's Avatar
Gmangh15
6.0 injectors
I just found out that the cause of my high pressure oil leak was from the left side injectors. I'm gonna replace all four. I've heard once some go out that they all could. What do y'all think on this?
Old Nov 18, 2011 | 01:11 PM
wulfman's Avatar
wulfman
That sounds kinda odd that the injectors are causing the high press oil leak. Who told you this?
Old Nov 18, 2011 | 01:34 PM
brickie's Avatar
brickie
A broken o-ring on the injector at the oil rail will cause a huge leak.Improper installation of the oil rail can cause damage to the o-ring.
Old Nov 18, 2011 | 01:36 PM
Gmangh15's Avatar
Gmangh15
I have it at a mechanics shop. He checked the hpop and it was fine, and teh icp valve, which was fine. So he checked the left side of the injectors and he said thats where it was.
Old Nov 18, 2011 | 03:17 PM
wulfman's Avatar
wulfman
OH!!!!!!!!!!!!
Old Nov 18, 2011 | 07:42 PM
_Me2_'s Avatar
_Me2_
So you're looking at spending $1000+ or so for 4 injectors to fix a bad o-ring? If the injector itself is actually bad, I would replace 1 injector. If it's the o-ring, I would replace all of the o-rings and call it a day.
Old Nov 18, 2011 | 08:08 PM
zhilton's Avatar
zhilton
I agree, if it's just leaking HPO...replace all four sets of o-rings/washers and be done with. Four o-ring kits at my Navistar dealership cost me $35 (Int 1843682C91) summer of 2010. No need to replace the sticks themselves unless you upgrading something "wilder".
Old Nov 18, 2011 | 08:46 PM
bismic's Avatar
bismic
I don't believe the kit #1843682C91 includes the HPO o-ring,. etc.
For that you need Alliant Power Injector Seal Kit AP0002
Old Nov 19, 2011 | 07:39 AM
zhilton's Avatar
zhilton
That Navistar part (1843682C91) is a "set" that comes with both o-rings for the injector barrel (white & black), copper washer and the o-ring (blue) for the pig-tail plug in the rocker box.
Old Nov 19, 2011 | 08:17 AM
npccpartsman's Avatar
npccpartsman
But it doesn't have the D-ring in the top of the injector where the oil rail fits into the injector, which is where the HPO leak is. For that you need the alliant set.
Old Nov 19, 2011 | 11:25 AM
zhilton's Avatar
zhilton
Brain fart, I'd forgotten about that o-ring. Maybe I need two cups of coffee before posting on the forums?
Old Nov 19, 2011 | 04:35 PM
bismic's Avatar
bismic
Thanks for the back-up Tim!!!!
Old Nov 22, 2011 | 07:53 AM
patrickke's Avatar
patrickke
For that price on injectors you could send them to Warren Diesel and get all your injectors freshened up
Old Nov 22, 2011 | 09:50 AM
Gmangh15's Avatar
Gmangh15
Well he replaced all 4 left side injectors and now there is a problem still with the pressure not being high enough. He said it fluctuates up and down. What do y'all think is the cause. He checked the hpop and the icp and said there were fine.
Old Nov 22, 2011 | 10:56 AM
patrickke's Avatar
patrickke
Do you have a fuel pressure gauge?
