Dash Screen and Reverse Camera
Old May 23, 2018 | 05:26 PM
Frankm1103's Avatar
Frankm1103
The screen on my dash always comes up on the same screen (the towing screen) when I start the truck. Once the truck is started, I can change the screens to whatever I screen I want. Also, about a week ago, my reverse camera started working intermittently. Most of the time, I get a blue screen and a message saying "Camera Unavailable." I'm going to be taking back to the dealer but wanted to run these scenarios by you guys first.
Has anyone run into these issues?
Thanks,
Frank
2017 F250 SD
Old May 23, 2018 | 06:29 PM
Austin_F100's Avatar
Austin_F100
Mine did that after I had towed a trailer. Go back into trailer setup and make sure "no trailer" is selected. Then it should default to your desired screen each time (in my case, the speedometer). Don't know about the other, but sounds like a dealer problem. Hope this helps.
Kurt
Old May 23, 2018 | 06:30 PM
slapshot12's Avatar
slapshot12
To get rid of the towing screen, go into towing settings, change trailer, and select no active trailer. Can't help with the camera other than recommending checking the connections.
Old May 23, 2018 | 06:38 PM
Frankm1103's Avatar
Frankm1103
Thanks! I didn't even think about going into the settings. I'll give it a shot!
Thanks again!
Old May 23, 2018 | 08:13 PM
Xwild's Avatar
Xwild
And to keep it from going back to trailer all the time after you tow again, unhook the trailer with the truck running. That way it will recognize it getting disconnected. For some reason it's not quite smart enough to realize you disconnected it when you start up and it's not there anymore.
Jd4230
Mar 2, 2024 01:19 PM
Sprucestroke
Apr 16, 2019 10:16 AM
exoilfld
Jul 12, 2017 08:02 PM
twesslen
Mar 30, 2017 08:43 AM
