Can you only get the Intelligent Access and Push Button Start with the Lariat Ultimate Package? Does the regular Lariat Value Package come with just the standard ignition key and no push button start?
the lariat regular and value package are the keyed ignition.
From what I’ve gathered the electricals for the premium vehicles (king, plat, limited) are basically the same once you get to the ultimate package in the lariat. The non-ultimate lariat has more in common with the lower trims.
adaptive cruise, power running boards both require the lariat ultimate or the standard trim on the upper models.
I've got Lariat Ultimate and it's got push-button, but what's intelligent access?
vehicle locks based on proximity (you walk away with the fob, it locks) and can unlock without taking keys out of pocket (touch inside of door handle while close enough to the vehicle)
