Adding push button start?? - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-15-2018, 07:47 PM
Uzumati's Avatar
Uzumati
Uzumati is online now
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
sitting around bored tonight thinking about what I can do next and after being spoiled with the push button start on the loaner the dealership gave me while mine is in for death wobble, I was thinking about what it would take to upgrade my xlt. Just off the top of my head I would need the button, antenna, and forscan programming. Has anyone tried this? Is a new bcm needed or just enabling what is there?
Old 12-16-2018, 12:14 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Appears there is a substantial difference in dash wiring between XLT and Lariat. There is also a module in the center console that would have to be added. Looks complicated.
Old 12-16-2018, 05:43 AM
emac396
emac396 is offline
emac396 is starting off with a positive reputation.
What about adding it to a Lariat that doesn’t have it? I believe it only comes on Lariat Ultimate?
Old 12-16-2018, 08:15 AM
jstiltner
jstiltner is online now
jstiltner is starting off with a positive reputation.
Just thinking through it I would think these parts at a minimum.
New keys with the active transmitter
Start button
Dash trim where button goes
Replacement steering column parts to remove key lock and the immobilizer that transmits to your current key.
Console cubby and wiring for the key slot there in case the key battery dies or gets messed up.
The reciever device for the key signals.
That is the minimum that I can think of and that assumes all the wiring is there.
Old 12-16-2018, 08:25 AM
Poncho450's Avatar
Poncho450
Poncho450 is offline
Poncho450 is gaining momentum as a positive member of FTE.Poncho450 is gaining momentum as a positive member of FTE.
Sounds like a solution in search of a problem. I'll keep turning a key.
Old 12-16-2018, 08:56 AM
Uzumati's Avatar
Uzumati
After a little digging last night I think poncho450 is correct, even though my truck has the key cubby in the center console already adding all the antennas and other parts required make this a major overhaul. Still going to check with my service manager friend to get an idea on cost but it will probably wait till I trade in 7 years.
Old 12-16-2018, 09:10 AM
Poncho450's Avatar
Poncho450
Some things would be pretty cool to have for sure. But on the other hand some things are not worth the time, effort and $$$. This coming from a guy who's pissed away all kinds of money on stuff I really didn't need to do to vehicles over the years.
Old 12-16-2018, 10:25 AM
Flyct
Flyct is offline
Flyct is starting off with a positive reputation.
Trade it in on a new Lariat Ultimate. You’ll be surprised how much your old truck has held its value.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
