Push to start
Old Mar 18, 2019 | 08:49 PM
bugsiegel's Avatar
bugsiegel
Push to start
Looks to me that the 2015 and newer is when the push button start was introduced.
Was it standard equipment an all 150's or an option?
Thanks in advance
Old Mar 18, 2019 | 09:04 PM
seventyseven250's Avatar
seventyseven250
Thanks in advance
Optional with higher trim level trucks only, not sure which ones.
Old Mar 18, 2019 | 09:12 PM
ford390gashog's Avatar
ford390gashog
Standard on 501a and above.
Old Mar 18, 2019 | 09:46 PM
onug's Avatar
onug
So that’s the Lariat level and higher. Not on the XL or XLT
Old Mar 18, 2019 | 09:47 PM
Wiggums's Avatar
Wiggums
None of the XLT's have it, not even the 302A. Not sure if I'd want that since I usually keep my keys in the truck and don't want the battery drained.
Old Mar 19, 2019 | 09:11 AM
GlueGuy's Avatar
GlueGuy
Technically, they all "have it", it's just that the lower trim levels don't have the button. The auto-start sequence is built into all of them now.
Old Mar 19, 2019 | 09:22 AM
xzsbkn's Avatar
xzsbkn
Interesting - can 'Push To Start' be added to to an XLT easily? Have you heard of anyone doing it? I really like that feature and would love to be able to add it to the truck.
Old Mar 19, 2019 | 09:32 AM
ford390gashog
No, the FOB frequency are different, the harness is not there and neither is the required harness or console module. This has been researched before and the difference between a 302a and a 501a truck are vastly different in terms of parts and as built programming.
Old Mar 19, 2019 | 09:36 AM
Wiggums's Avatar
Wiggums
Darn, somebody makes it sound easy and ford390gashog, once again, uses his knowledge to shatter any hopes.
Old Mar 19, 2019 | 11:05 AM
GlueGuy's Avatar
GlueGuy
Pretty sure it's all there. I know on my XLT, all you have to do is "touch" the start position on the key, and the truck finishes the job. It's become such a habit that I frustrate myself when I get in a different vehicle, and you have to hold the key in the start position until the engine actually fires up.
My feeling is that all you really need to do is add the start button to the dash. You would still need to turn the key to on, but you "could" have a start button. So it's not the same, but the electronics is mostly there.
Old Mar 19, 2019 | 12:53 PM
CR172's Avatar
CR172
I myself prefer the key. My wife's Edge has the key less ignition and I just don't like having that big ol' fob in my jeans pocket. And I know for a fact that if I put the fob in the console or somewhere I'd forget it.
Old Mar 19, 2019 | 01:12 PM
ford390gashog
The self start function parameter validation test had been standard since 2011. It removes the user from the actual cranking of the engine and essentially self starts based on parameter validation. Much the same as a standby generator with a ATS. You are correct that both methods of starting do use this system as it's a final function of the start sequence. However when it comes to the other start sequence it's very different and handled differently.
The key equipped trucks require inserting the key and manual RFID validation at the ACC position ( momentary delay prior to start confirming validation) then the IPC sends the command to the SJB and PCM this is a 315hz system as Ford calls it in the service content. The pre start functions of the push button start gets confusing, there is a roving radar that detects approach in the door handle to allow easy entry, the information is pre sent to the module in the console to wake up and start scanning. Once validation has happened you can press the brake and push the start button.
Old Mar 19, 2019 | 07:51 PM
Destroked 450's Avatar
Destroked 450
Hopefully my XL based STX doesn't have a bunch of that crap, key fob has lock and unlock, that's all.
Old Mar 19, 2019 | 10:03 PM
ford390gashog
It still has the start validation sequence. All the trucks have since 2011. Its the reason why you don't need to hold the key to crank the truck.
Old Mar 19, 2019 | 10:57 PM
Destroked 450
You don't? haven't tried letting up on the key before the engine starts see what it does.
On all of our other vehicles you hold the key in the start position until it starts, I do the F-150 the same way.
