Sponsored by: Auxito
Bumper grill swap.
Old Sep 19, 2003 | 05:25 PM
nicechad2's Avatar
nicechad2
Bumper grill swap.
Has the issue on whether a 99 up f150 front end (bumper, grill,etc) will fit onto a 97-98 been resolved? Just curipous, I need to replace my bumper and grill and would like to upgrade when I do. Is the inner grill shell needed?
Thanks.
Chad
Old Sep 19, 2003 | 06:44 PM
NASCARTruckDude's Avatar
NASCARTruckDude
Bumper grill swap.
I would like to know too. I heard that when removing the bumper you gotta be careful with the air bag sensors because if they are activated the airbags could set off. This true?
Thanks,
Chris
Old Sep 20, 2003 | 12:55 AM
ford_tr_man's Avatar
ford_tr_man
Bumper grill swap.
you need the outer grill sorround, new bumper,new valance, you also need the top plastic peice that goes on top of the bumper, rubber garmet behind the bumper, and a new grill and that's it
Old Sep 20, 2003 | 08:08 AM
VARNEY1's Avatar
VARNEY1
Bumper grill swap.
you will need to download the airbag. just make sure the battery has been disconnected the for ten minutes and the airbag fuse has been removed for at least ten minutes. do not fool around with the airbag sensors if the fuse is not out and the battery is not disconnected.
Old Sep 21, 2003 | 08:15 AM
nicechad2's Avatar
nicechad2
Bumper grill swap.
What about the header panel behind the grill, between the grille and radiator supprt? Is that the same? What about the turn signals?
Old Sep 21, 2003 | 11:58 AM
VARNEY1's Avatar
VARNEY1
Bumper grill swap.
the header panel is the same, you may have to purchase some extra clips from an auto body suply company to accomodate the new pieces but that is not for sure. but the construction of the header panel is the same.
hasteranger
Feb 22, 2015 08:33 AM
breedo99
23
Jan 14, 2015 08:36 PM
DemonRace6
Jan 16, 2012 02:45 PM
pirate4x4_camo
Jul 17, 2011 06:29 PM
daveboys
Apr 6, 2010 01:57 PM
