Sponsored by: Real Truck
Major brake problem. Befuddled!!!!
Old May 19, 2018 | 12:44 PM
devo2810's Avatar
devo2810
I’ve got a 2004 f-250. New calipers and pads on the rear. 3 yr old calipers in front (decent pads) After installing rear calipers and 4 caliper bleed, I’m still getting soft or squishy, peddle to the floor brake pedal. I had my girl pump the brakes while I checked all the lines for leaks. And have found nothing. Any help WILL BE forever appreciated.
Old May 19, 2018 | 01:00 PM
prokopovychbohdan's Avatar
prokopovychbohdan
After bleeding calipers did you refill the brake fluid reservoir all the way AFTER you pumped the brakes? Have to pump the brakes and keep filling until full.
Old May 19, 2018 | 01:05 PM
devo2810's Avatar
devo2810
Yep. And still not gettin the right peddle pressure.
Old May 19, 2018 | 01:08 PM
T diesel's Avatar
T diesel
ARE YOUR BLEEDERS ON THE TOP OR BOTTOM?
Oops caps were on!
Old May 19, 2018 | 01:11 PM
prokopovychbohdan
How are the brake lines? I'm assuming they're rubber. Do they feel or look a little old? Pinch a line with your finger and see how easy it is to do. If the lines seem a little soft then they could be losing pressure when you step on the brake. I know a lot of people will replace brake lines on motorcycles to braided steel lines becasue their brakes are too soft.
Old May 19, 2018 | 01:14 PM
devo2810's Avatar
devo2810
Front bleeders are up. Rears are down. Replaced 1 rubber line on the drivers rear. All others are original. Will pinch check them.
Old May 19, 2018 | 01:18 PM
T diesel's Avatar
T diesel
Your rears are wrong. They have to be on top. you will never bleed them.
One of them belongs on the other side.
The other is wrong.
Old May 19, 2018 | 01:52 PM
devo2810's Avatar
devo2810
I heard that someplace. Bleeder positioning that is. I’ll be back with updates. Dodging rain drops.
Old May 19, 2018 | 02:02 PM
T diesel's Avatar
T diesel
You're not the only one!
https://www.ford-trucks.com/forums/1...l#post16003671
Old May 19, 2018 | 09:54 PM
afmedic's Avatar
afmedic
If you're in a pinch and have to drive it before you can get the new calipers you can take those off, and stick a clock of wood in them. Then you can position the bleeder on top and bleed the air out. Not ideal but it'll work
Old May 19, 2018 | 10:31 PM
SuperDutyScaler's Avatar
SuperDutyScaler
All he did was put the right on the left and the left on the right. Go buy new brass washers and flip the rear calipers to opposite sides. Then bleed the brakes again, start rear right then Rear left he front right and finally front left
Old May 20, 2018 | 08:42 AM
devo2810's Avatar
devo2810
Switching this morning. Every time I went outside to work on her, it’s started to rain.
Old May 20, 2018 | 10:24 AM
Sullid01's Avatar
Sullid01
I think you have probably fixed your swish brake pedal. FWIW I have replaced probably 10 calipers on my truck. I really think you need to do brake lines anytime you do the calipers. Since I started doing that and brake fluid flushes with tire rotation, no more new calipers. Also stainless braided brake hose seems a worthwhile upgrade - those are the one I used the last time.
Old May 20, 2018 | 10:36 AM
devo2810's Avatar
devo2810
Done. Not perfect. Back to normal. Replacing rubber lines may help. Major appreciation for all the great insight. Y’alls the best!!!!😁
Old May 20, 2018 | 03:40 PM
T diesel's Avatar
T diesel
glad to help!
dixiehornford
May 9, 2018 12:14 PM
1oldlongbed
Jun 14, 2017 08:57 PM
mattd860
1983 - 2012 Ranger & B-Series
Jul 1, 2011 08:57 AM
gtripledip
Dec 3, 2006 09:32 AM
judie61364
Oct 16, 2004 07:50 PM
