Budget Roof Rack
Old 05-18-2018, 06:48 PM
Richwon4's Avatar
Richwon4
Richwon4 is offline
Budget Roof Rack
Of course we know the stockrack isn't worth much. I need a competent rack that will haul canoes. Never more than 100#. I don't need the best but need something functional. Thank you.
Old 05-18-2018, 07:42 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
You mention budget but didn’t specify how much your budget was ?
Old 05-19-2018, 06:19 AM
Richwon4's Avatar
Richwon4
Richwon4 is offline
Budget
I cannot spend 300$ on up. 150-200 would be ideal, less even better.
Old 05-21-2018, 06:48 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
If you have access to a welder it should be possible. These connect to your existing rail with the sliding/tapped squares. Can use lighter gauge metal or aluminum as needed.
Old 05-21-2018, 08:49 AM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
You make those Sean? Look very nice. Post some picts with them installed. Thank you.
Old 05-21-2018, 10:34 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Nah Jim, just took 'em off the interweb.
Old 05-21-2018, 12:17 PM
roadrnnr's Avatar
roadrnnr
roadrnnr is offline
When I decided to make my racks useful I want them to remain a stock as possible. I ended up building them up off the roof with some flat stock PVC and ordered longer stainless bolts to replace the stock ones. I painted the PVC black and put an innertube under each one to prevent rubbing. It works pretty well, was pretty cheap, I say under $50, and allows me to put my cargo carrier on the roof for trips.
Vince79vette
05-22-2018 08:00 AM
DSN46
03-13-2018 01:49 PM
xkpsanit
07-24-2015 11:44 PM
hobbystock98
Paint & Bodywork
13
07-01-2011 06:36 PM
ranger429
1978 - 1996 Big Bronco
09-29-2008 02:15 PM
Quick Reply: Budget Roof Rack
