Finally found noise!!!
Old May 18, 2018 | 06:12 PM
MabelF250's Avatar
MabelF250
Ok guys, so for the past few days i have heard, like a whirling noise, or like a faint whistle/ fog horn sound coming and going under the hood. The truck ia a 1996 7.5l. Today was inline at pharmacy, heard it again. Drove home, and was still doing it, and even alittle louder. Originally thought could be water pump possibly on its way out. But today crawled under hood, and really put the ear down close to everything i could, and it sounded like from the air intake, it has the banks one on it, so i started pulling the intake apart, and kept listening, as i went, i narrowed it down to the throttle body area, and then, it got louder as i got closer to the IAC. I unplugged it and sound stop immediately. The RPMs dropped as they should. And truck has no codes at all... is this sounding right??? Never heard an IAC make that noise before. But did stop as soon as i unplugged it. Is this noise normal, anyone heard of this? Thanks for input. I did order a Ford one just because
Old May 19, 2018 | 06:06 AM
bad_idea's Avatar
bad_idea
Here's a wild stab in the dark. Take it for what you paid for it.
If the IAC is like other vehicles I have messed with, then it is an electrically operated valve that opens at a variable rate to allow more air into the engine. If it is filthy, then it could create a weird passage for air to pass through. I would suggest you disassemble it and clean it with some throttle body cleaner. A good idea to clean the whole throttle body while you are at it. I wouldn't put a new one in just yet, sounds like it is still functioning. When you unplugged it, it closed, and stopped making noise.
Old May 19, 2018 | 07:18 AM
MabelF250's Avatar
MabelF250
Ya, im assumming its what your saying, just really dirty. I have already ordered a new one, and they are cheap enough i will just go ahead and put it in, see whay happens. But thanks for the input...
Old May 19, 2018 | 07:20 AM
bad_idea's Avatar
bad_idea
I'd say clean the throttle body up real good or the new one will act the same. I think it is dirty passages causing the whistle effect.
Old May 19, 2018 | 07:43 AM
MabelF250's Avatar
MabelF250
Yes, i will clean throttle body up, before new one goes in.
Old May 19, 2018 | 08:36 AM
Scndsin's Avatar
Scndsin
Be advised, that the throttle body came with a sticker saying "do not clean".
The blades have a coating.
Some get away with it, others immediately have idle issues.
Old May 19, 2018 | 08:41 AM
MabelF250's Avatar
MabelF250
Yes, i saw that sticker on top of my throttle body. Not sure what to clean now. Going to try and not clean the blades and to see how bad the passage ways are before i start spraying things down with cleaner. Thanks for input
fordman19762003
6.2L V8
Jun 27, 2017 02:29 PM
Aftrmidnite
1997 - 2003 F150
Jun 2, 2013 01:08 PM
casey bartlett
1997 - 2003 F150
Nov 22, 2012 04:44 PM
F3fitty
May 6, 2011 12:28 PM
fkaster01
Apr 18, 2009 11:03 PM
