pulls well but will not spin the tires on dry pavement
My 1977 F150 400ci engine performs well (certainly better than my 2004 f150 w/ 4.6), however I am trying to decide what and if there is more I can understandably do to the timing gear, cam or valve train?
The 400ci long block was replaced the summer of 2003. The long block was purchased from O’Riellys. I do NOT have the specifications for it but this is what I have. I have used since last summer pulling a 28’ travel trailer.
The engine has around 20,000 miles. Below is more information.
COLD compression test: (1) 120 (2) 115 (3) 115 (4) 115 (5) 105 (6) 120 (7) 110 (8) 105. I think this is above average.?!
625 Street Demon tuned with an A/F gauge
1” spacer
Performance 400 dual plain intake
1-3/4” long tube hooker headers
Dual exhaust, 12” resonator, single chamber mufflers, out in front of rear wheel
Cam, I tried to measure the rocker at top of the pushrod. I got .425-.450 ish, both intake and exhaust. I have no other information.
Timing chain, it could be 4 degrees retarded, I don’t know. Would they do that (not install straight-up)?
I like the truck, it does the job. I “feel” the HP and torque is nearly 300hp and 350 ft lbs. What is your estimation?
I can afford a new timing set and cam. I am wondering, is this engine worth a new cam and timing set or should I just ride it off into the sunset.
Side note, it is a 400, C6, 3.55 Detroit locker 2wd, stock tire size equivalent, pulls well but will not spin the tires on dry pavement.
Thank you for your time,
JD
1” spacer
JD
1977 Ford 400 was about 170 netHP at 3400 RPMs stock when new... about 210 crankHP with headers... actual compression ratio was about 7.6:1... since there were no good 'rebuilder' pistons available, your compression ratio is prolly even lower because pistons sit even lower than stock... the rebuilder may have used the stock overly retarded cam spec.s, as well, to meet emissions requirements... the cam is prolly about a 184/194 duration at .050" lift... Your added 4 bbl. carb. has prolly restored you back to stock HP or a tad higher and added a bit more high RPMs...
As is discussed in most threads here, your only real solution for more power is TMI pistons... the stock cam was too big for the stock compression ratio and going bigger cam just makes matters worse.... will give even less tire spinning torque... more cam simply requires better pistons...
I'd suggest TMI pistons to get compression ratio up into the 9's and a Summit 5201 cam of 218/228 durations for a serious boost in power and torque on a budget... anything else is just spinning your wheels as far as getting more power... TMI pistons are the ONLY off-the-shelf performance pistons available that simply go right in... 150 - 175 psi compression pressure... We're talking around 350 HP at 4500 - 5000 RPMs and 450 - 475 ft-lb torque... improved MPG...
https://www.summitracing.com/parts/sum-k5201
Also, an adjustable timing set:
https://www.summitracing.com/parts/s...view/make/ford
(You may be able to get tire spinning torque out of your current setup by making sure the secondaries of the 4 bbl. carb. aren't opening from a standstill... advancing the cam timing... carb. may have come with #62 - 66 primary jets for a 302" or 351" engine, prolly needs about #70 - 72 jets for a 400... these engines were actually 402" new, prolly 406" - 408" now, depending on overbore... maybe even larger...)
ThatFordGuy
05-16-2011 11:25 PM
jwrboss302
04-10-2004 01:38 PM
