Cam timing for 400
Old Jun 22, 2003 | 05:28 AM
dposey's Avatar
dposey
Trailering
Cam timing for 400
I have a 78 F150 with a 400 and TCI C6. The 400 has an Edelbrock performer intake and carb, Melling RV cam and timing set, and Hooker Super Comp headers with dual exhaust. The EGR is connected and functional. The cam timing is set at the factory key, although it has 4 degree advance or retard keyways. My question is this: Should I have set it at the 4 degree advance? Several of the other posts on this site refer to retarded cam timing with the 400. It has good torque, but more would be better.
Thanks for sharing your knowledge.
Old Jun 22, 2003 | 01:21 PM
bubbaf250's Avatar
bubbaf250
Cam timing for 400
Cam timing is specified by the cam manufacturer in terms of crankshaft degrees past TDC when the lifter is on the intake lobe centerline. If the timing set has multiple keyways in the crank sprocket, the 0 (zero) position should set the cam timing at the specified position.
Degreeing the cam is the only way to know for certain what the cam timing is. Both Comp Cams and Crane have good descriptions of the cam degreeing procedure on their web sites.
Old Jun 27, 2003 | 06:15 PM
There Goes The Neighborhood's Avatar
Cam timing for 400
factory cam timing as set by ford is 4 degrees retarded. you did probably the best thing for the engine by setting it at 0.
jdhreiss
18
Jul 22, 2017 10:12 AM
farmpaw
20
Mar 20, 2016 06:41 PM
mustang81
Mar 2, 2008 06:22 PM
400Nut
Jun 13, 2006 07:44 PM
jwrboss302
Apr 10, 2004 01:38 PM
