Sponsored by: Real Truck
No boost
Old May 17, 2018 | 05:58 PM
MTP55's Avatar
MTP55
No boost
Truck is a 2010 6.4. 130k. Stock. My cousin in Florida owns this truck just bought it a couple months ago. I live in Michigan so I have to go off what she says. She says it won't build boost and is throwing a couple codes. I went through and told her to check the MAP sensor, as well as for leaks in boots and tubes. Air filter was just swapped for another stock one. She says the wheel in the exposed turbo can spin with the truck off. I am not familiar beyond basics with a 6.4. She is on a naval base in the keys so apparently not many diesel mechanic down there unless you drive a couple hours. She says there's no visible exhaust. I also told her to check the wastegate actuator. And EBP. Because it threw a code for that. What else is there?
dunefaber
Sep 18, 2016 06:49 PM
PJ-Hunter
Apr 11, 2016 10:52 AM
Pitcrw6
Jun 17, 2011 12:09 PM
timmyboy76
May 11, 2011 11:20 PM
StampedePSD
44
Jan 11, 2009 12:21 AM
