What about the overboost annihilator?
Old Jan 7, 2009 | 04:33 PM
StampedePSD's Avatar
StampedePSD
I saw an overboost eliminator on ebay for 45$. Says it gives more boost, drops the egt and so on. What about too much boost?
How do these work and are they safe?
Thanks,
Lusty
Old Jan 7, 2009 | 04:36 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You'd be better off getting a "known-good" product like what ITP Diesel sells:
ITP's Overboost Annihilator
Same price and many people here use it. I'll be ordering one in the next few days myself
Old Jan 7, 2009 | 05:01 PM
superduty4x4's Avatar
superduty4x4
Never heard of an overboost annihilator dropping EGT's... I have (somewhere) a free version of an overboost eliminator but the jury's out as to whether it actually works or not. I should pop that sucker in one of these days...
Clicky
Old Jan 7, 2009 | 05:02 PM
ron's power stroke's Avatar
ron's power stroke
it will not give you more boost or lower the EGT's..it just hides what boost you can make from the map sensor so the truck dont defuel its self..with a chip a stock turbo can build 30 lb but going over 25 lb of boost the stock turbo wont last long...
Old Jan 7, 2009 | 05:14 PM
superduty4x4
Nice to see you Ron, been wondering where you were hiding.
More reading on the Zener diode mod- here and here.
Old Jan 7, 2009 | 05:38 PM
canuckelhead's Avatar
canuckelhead
And you can avoid the overboost annihilator if your tunes from DP come with code, correct?
Old Jan 7, 2009 | 05:42 PM
superduty4x4
I believe so Rick.
Old Jan 7, 2009 | 05:43 PM
ron's power stroke
thanks Chase..i been busy the last couple weeks...
Old Jan 7, 2009 | 05:52 PM
superduty4x4
Know the feeling... plow show, shovel snow, sleep, repeat.
Old Jan 8, 2009 | 08:09 AM
StampedePSD
Can my BD thruster turbo handle more than 30lbs? What about the other parts. I thought that over 30 and joints and seals would start blowing? If anything, I wouldlike the turbo to come on stronger, earlier, say 10-15mph.
Do the TDP tunes already have this feature for hiding boost?
Lusty
Old Jan 8, 2009 | 08:18 AM
jdecker88's Avatar
jdecker88
Well if BD makes as good as a product as they swear they do then you should be okay. I have the stuff to do my DIY kit but I have been reluctant to do it since I really don't want to lose my stock turbo until I can find a van. I am not sure if Tony does those codes or not.
Old Jan 8, 2009 | 08:25 AM
bdrummonds's Avatar
bdrummonds
Lusty
The BD thruster turbo appears to be a journal bearing design, with the same A/R as a stock turbo. It does have a ported housing which will eliminate surge, but since the A/R has not been increased to relieve the excess drive pressures I do not believe I would run this over 27-30 #s
If you want faster spool then get the TW or DP chip and you wont have a problem, the Superchips does not add enough fuel on the low end to spool your turbo as quick as you would like.
IIRC, the DP no code tunes only keep the SES light from coming on, I do not believe they actually hide the true boost from the PCM to the map like a regulator would.
Old Jan 8, 2009 | 09:43 AM
StampedePSD
I have the TW chip coming. To be delivered tommorrow. I look forward to seeing if the turbo spools quicker. Is there anything you can do to the BD turbo like housing or something to handle more boost?
Lusty
Old Jan 8, 2009 | 10:11 AM
Bigfwt04's Avatar
Bigfwt04
Brandon was describing how to make your own OBA locally and have it function identically to ITP, or BD's. Sounded like it would save you some money to depending on if you found a good deal and of course no shipping. Maybe he will post it up for us...
Old Jan 8, 2009 | 10:36 AM
jdecker88's Avatar
jdecker88
It is just fuel line and a air pressure regulator it wills ave you about 20 dollars.
