Hesitation in the 1500 to 2k RPM zone
2000 F250 Lariat V10 179k
The truck has a miss in the rpm range and when it shifts to OD. The truck also seems to be running rich from the smell of the exhaust. There isnt CELs present and ive replaced the plugs with motorcraft plugs, New MAF, Air filter, ran 2 bottles of Seafoam in the tank.
things I plan on checking/ replacing next
PCV and hose, (elbow)
checking the resistance on COPS
cleaning the TB
replacing the fuel filter.
Any input would be appreciated. I really dont want to blindly throw money at it.
cleaning the TB
how is a good way to check injector plugs?
I'll have look into misfire counters also. Not sure how to go about that
Does the problem start when it's still cold first thing or when it heats up? Does it have trouble starting and idling at first? If you haven't at least thrown a code reader on it you should give that a shot to see if there are any stored/pending DTC's. Fine at WOT and rough at partial sounds like possible vacuum leak or O2 sensor.
I bought one COP and kept switching is around. I cant remember if it was 3 or 4, but definitely right side. Then I did ALL boots and plugs (200k miles) and it completely went away.
I was replacing the spark plugs anyhow. SO I just did them all. The current ones had at least 120k miles that I drove ti without replacement, And the truck had 80k on it when I bought it. They may have been original.
tankhokie
07-08-2004 12:15 PM
