Manuel transmission
I mounted a T5 out of a 1999 mustang onto my 302. I had to make a new transmission mount, and get a new driveshaft... For the clutch I purchased a wildwood pedal, master, and slave cylinder and converted it to hydraulic. The clutch conversion was the biggest pain. If you have the engine out of the truck it would be much easier to set the throwout bearing distances.
There's nothing better than having that third pedal though!
Don't forget that you will need a pilot bushing for the end of the crankshaft. Without it the clutch will work for a little while then develop a serious vibration before destroying itself.
https://www.novak-adapt.com/catalog/pilot-bushings
Vintagerestoration
01-21-2019 09:55 PM
52'F-3
09-14-2012 04:15 AM
48prerunner
03-10-2012 11:07 PM
ccarrier
18
06-22-2010 08:49 AM
