Sponsored by: Real Truck
Rust Damnit!
Old May 14, 2018 | 01:34 AM
charlie46's Avatar
charlie46
Trailering
Unhappy Rust Damnit!
2000 F350, 227K Miles. Replacing nylon fittings on the lower door seals today (crew cab, four seals) and found both front doors having rust at the bottom, actually pushing out the door skin. Pulled the the insides, both are clean inside. Suppose I'll take a wire brush to them, heavy primer and POR-15. Anybody else seeing the bottom edge of their doors starting to corrode?
Old May 14, 2018 | 03:21 AM
seville009's Avatar
seville009
Door edges snd wheel rims - on my 2006 f350
Old May 14, 2018 | 05:39 AM
CollinsCD's Avatar
CollinsCD
Drivers side rear wheel well 2010 F250 rusting through!
Getting ready to have a body shop cut it out and replace with a patch panel.
Old May 14, 2018 | 06:19 AM
speakerfritz's Avatar
speakerfritz
careful not to clog the drain holes
Old May 14, 2018 | 06:40 AM
Chuck's First Ford's Avatar
Chuck's First Ford
WOW,,, no location given.......... Rust...
I have had cars rust so bad.. from new to junk yard in 10 years.... and under 100,000 miles...
best car I ever owned.. went from 1988 to 2004.. and 255,000 miles.. to the junk yard... frame rusted to nothing... nothing will stop RUST.. nothing..
ask the U.S. Navy...
Electronic anti-Rust devices.. only slow it down by 1-2 years...
N.E. Ohio .. Lake Erie Salt...
Old May 14, 2018 | 06:58 AM
FractureCritical's Avatar
FractureCritical
lol. yeah. these trucks suck for rust.
POR-15 before the primer, and make sure you use at least two coats (three preferred). POR-15 won't work unless you get all the pinholes in the coating.
Old May 14, 2018 | 08:28 AM
Batman7777's Avatar
Batman7777
Are these trucks in locations where they use salt on the roads (Winter)? Close to salt water (Miami)? Wet locations where it always rain (Seattle)?
I had a Ford Super Duty going on 13 years and never saw any rust.
There are places you can take a truck in for under coating, door panels, fenders, etc protection.
Old May 14, 2018 | 08:39 AM
finn's Avatar
finn
There’s a reason that there are so many cab corners, inner and outer rocker panels and door bottoms, and bed wheel flares available in the aftermarket.
Old May 14, 2018 | 09:04 AM
Mike1's Avatar
Mike1
And I need everything you mentioned for my 03 F350. Chicago area hasn't been good to this truck at all.
Old May 14, 2018 | 09:45 AM
Yoteman's Avatar
Yoteman
Yup, bottom of the two front doors have a tad bit of rust. Both back fenders have a small hole in each. I’m getting ready to cut the rust out and weld in new metal. It’s very frustrating.
Old May 14, 2018 | 09:57 AM
ggazz50's Avatar
ggazz50
Don't feel bad, metal does eventually rust. My low mileage '99 has some light rust starting on the inside lower edge of the doors too.
Old May 14, 2018 | 09:58 AM
Batman7777's Avatar
Batman7777
For vehicles in rust prone areas...There are others.. but the one I remember is..
Is Ziebart still around? Ziebart | Home
Old May 14, 2018 | 10:05 AM
Sparky83's Avatar
Sparky83
yup all 4 side doors right along the bottom on the inside panel.. and the cross members for the bed are rotted out...
Old May 14, 2018 | 10:45 AM
Batman7777's Avatar
Batman7777
This looks like a good selling point for the all new aluminum body, but not gonna help for everything else.
Old May 14, 2018 | 12:49 PM
Chuck's First Ford
Ziebart.. after 2 front door replacements (from junk yard) they returned the money I paid for the coating. on my wife's car.
so much for there warranty...
read the FINE Print..
