Sponsored by: Real Truck
Rust Damnit!
Old May 14, 2018 | 04:44 PM
SuperDutyScaler's Avatar
SuperDutyScaler
My 04 is in south Jersey, salt and brine all winter long and then in the summer I drive to ocean city nj to salt water fish. My trucks pristine with zero rust
Old May 15, 2018 | 10:06 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
'06 350 in MA. Salt area, plow truck, farm truck. My front axle housing is in danger of rusting through. The body? Over the wheel wells in the rear, bottom of the doors. Trans cooler lines, power steering lines, exhaust manifolds, skid plates, rear brake backing plates. Lost count of how many brake calipers. Frame is pretty flaky. 60K miles.
Old May 15, 2018 | 10:38 AM
Batman7777's Avatar
Batman7777
Wow!! I recently sold an 06' 350... No rust anywhere.. The truck was primarily located in Colorado, New Mexico and Texas.
The State or Federal Gov should reimburse residents in rust prone areas due to road salting. Don't hold your breath...
I do wash my truck after each snow in Colorado.. It's a pain.. but I do it...
You can buy undercoat in a spray can.. Might help some, and if it does anything, you might save a lot.
Old May 15, 2018 | 10:49 AM
NewEnglandHerdsman
It only gets worse. The new thing isn't just road salt, but "brine", a salt (including the much more corrosive magnesium chloride) and water mix that's used to pre-treat the roads. The brine gets into every crack and crevice that the regular salt granules can't, at least before they're dissolved into slush. Washing is probably a good thing, but it's possible it's just pushing the brine farther into the cracks, lol.
Oh, and in the "rusted away parts" list I forgot to include the front drive shaft - the tube rusted to the point that it exploded while plowing.
Old May 15, 2018 | 11:08 AM
Batman7777's Avatar
Batman7777
Colorado uses Magnesium Chloride along with mixtures of sand and sand/salt mixture along with various liquid anti-icers and de-icers.
Thorough cleaning of your vehicle is a must. Colorado DOT states the liquid anti-icers are easier to clean off than traditional salt and will not harm paint (Not so good for under carriage).
They are mostly concerned with environment and cost savings. I take the truck to a manual car wash and high pressure spray underneath.
https://www.codot.gov/travel/winter-driving/faqs.html
Old May 15, 2018 | 12:35 PM
SteveH-CO's Avatar
SteveH-CO
When you are all done with any metal repair, be sure to squirt ATF or aerosol Lithium grease into the door seams (remove the door panels, and squirt from the inside). Once you have oil or grease in the seams, they will not rust again. You will have to wipe off the doors on occasion, as the oil weeps out, but it beats rust. After you treat the doors in this manner, shut them against a piece of newspaper to soak up the initial drips.
Old May 15, 2018 | 12:44 PM
NewEnglandHerdsman
For my first trucks, where the ah.. appearance wasn't their strong point, whenever I changed the oil I used to pour the drain oil down the window slots and in the cab corners. That was way back when you wouldn't get shot for spilling oil on the ground.
Old May 22, 2018 | 10:26 AM
MDSuperDuty's Avatar
MDSuperDuty
I've been garaging my truck in the winter for years now. Buying used cars/suv's to drive in the winter and eat up the salty roads. My truck is bought and paid for so I'll probably get into the leasing game for my next vehicle instead of the used ones. Return them for a new one every 2-3 years and it's under warranty and no need to do any major work. Living in the rust belt that's the only thing that makes sense to me. Holding on to vehicles driven in salt is an absolute headache. Everything just gets destroyed and is a mess to work on. Fluid Film has helped me slow the process but I'm past the point of wanting to do all this work to keep a vehicle rust free outside of garaging it. I applaud those of you who go the distance to protect your vehicle but I feel it's just a losing game in the end when living in the rust belt. I know you get "nothing" form a lease besides a payment but you don't get much when trying to sell a rusted out vehicle.
Old May 22, 2018 | 10:49 AM
phillips91's Avatar
phillips91
My 2000 has had major rust issues. Brake lines, differential covers, frame and bed rails. Never been off road, garage kept, never driven in winter, etc.
My 97 250 I had was driven off road weekly, all winter, washed once every couple of months and used like a work truck. Did not have one spot of rust when i sold it.
My bronco has rusted out tailgate, quarters, brake lines, etc and was driven on the same jobs as my 97.
My escape has been garage kept, no winter driving, etc and has some rust around the wheel well.
Old May 22, 2018 | 02:18 PM
4Wheelgreg's Avatar
4Wheelgreg
My last ford was a 2001 f350 tail gate started popping at the seals the first year and I am the guy who washes under side after every snow and salt application by the wonderful Penndot . The second year with my 2001 I had to POR15 the underside of the truck to keep the truck from rusting away .
I have not had a ford in 16yrs and just picked up a very low milage 2016 F450 was used in the salt a few times , aluminum has the powdered salt look and slight popping on the edges of the spot welds on the underside of the body .
I allready gave the under carriage a good few washing , I'm planing on doing the same thing I did with my 2001 and coating the frame and underside of the body with POR15 .
Old May 22, 2018 | 06:52 PM
T diesel's Avatar
T diesel
For $150.00 a year.....
https://www.krown.com/en/
Problem solved.
Do it when your baby's new.
Old May 22, 2018 | 07:48 PM
NewEnglandHerdsman
Problem solved.
Closest place is 150 miles from me. Might be worth the drive...
Edit: Read a little more. This is body panels only (I should have realized that), i.e. the warranty is against rust-through in the body panels. There's a life time maximum of $5000 in warranty for aluminum vehicles.
Old May 23, 2018 | 07:13 AM
  #28
FractureCritical's Avatar
FractureCritical
Problem solved.
I think the point you're missing is that you shouldn't have to do this. many many MANY other cars far cheaper than our rigs have a few pennies more of rust protection from the factory and have zero issues.
I take specific offense to the fact that since Ford can't spend another $150 on a $40k+ rig, the owner has to spend that or more every year getting the underside of the truck lubed up like it's pr0n star.
it's not right. I hope the aluminum helps the sheet metal life, but that''s hardly the only rust points on these trucks.
Old May 23, 2018 | 10:31 AM
  #29
MDSuperDuty
The aluminum bodies haven't been around long enough but I'm curious to see what a truck looks like in 5 years here in the rust belt. Even better if it has a little paint damage that exposes the aluminum to the salt and other materials they use. Aluminum can corrode so for me the jury is still out until I can see a truck that has bathed in the salt. I've seen what can happen to some aluminum wheels when exposed to salt. The other thing is the non body components are still steel so those issues will still exist. But dealing with a body that has some pitting vs. full out flaking off rust is probably better.
Old May 23, 2018 | 10:52 AM
  #30
T diesel's Avatar
T diesel
I'm not "missing" anything.
I'm dealing with a shi**y reality.
