my luck continues.....
Old May 14, 2018 | 08:08 PM
Josh Rowe Sr.'s Avatar
Josh Rowe Sr.
I'm getting a temp gun tomorrow from a buddy. I replaced some vacuum lines and the cam sensor today because she didn't want to start. she's running better but not like she should. I bet I'm having the connection issue in one of my banks... I'm ordering new map sensor, boost annhilator, new silicone boots, 6637 filter, and a wicked wheel on friday! gonna be a xmas soon lol
Old May 14, 2018 | 08:09 PM
Josh Rowe Sr.
might go ahead and do the o-rings on the injectors while I'm in there. I'm definetly changing the glow plugs also.
Old May 19, 2018 | 03:41 PM
Josh Rowe Sr.
ok so update. map sensor was definetly bad. ordered from riffraff last night along with a 6637 air filter. also found the vacuum lines for the map sensor and turbo blowback were leaking bad. the way shes running without the map sensor, i can't wait to see how shes running with a new map and air filter.
ordering riff raff's boot kit, clamp kit, aih delete with gauge attachment and code delete wire next week. then i need to fix my front end lol. But, having fun with the build!! Thanks everyone for the help!
Old May 20, 2018 | 03:14 PM
hydro man 17's Avatar
hydro man 17
"also found the vacuum lines for the map sensor and turbo blowback were leaking bad"
Just an FYI but there are no "vacuum lines" on a diesel engine. The vacuum for the ESOF, if equipped, is supplied by a separate vacuum pump.
CousinCarl
Mar 4, 2018 09:35 PM
brenterf
6.7L Power Stroke Diesel
18
Jun 4, 2015 03:18 PM
MHammer21
33
May 25, 2011 05:21 PM
TNT
15
Aug 29, 2007 08:18 PM
Kingtim7
Mar 19, 2007 09:08 AM
