Two wheel drive has replaceable front rotors without hub just like 4wd, Ford said no can be, cannot find part# for two wheel drive without hub. I ordered truck inJanuary 2005 with traction lok rear, truck built in 1-05. Also has 2006 emission parts on intake with 2006 air cleaner. I need help with brake rotors to buy. Pete
I had same message from Ford, since then I downloaded dimensions for 4WD front rotors and will need to take front brake apart to check dimensions, hopefully they are same.These rotors do not look like they are pressed on.
I'd almost say you have the Centric conversion kit that is out there for our trucks. Check with them and you may be able to get the dimensions for the rotors to verify what you have?
I replaced miy front bearings and rotors with Centric a couple of years ago on my ‘06 rwd. They were the only company that had separate bearings and rotors. Sorry, I can’t remember the model number. Since I was doing that I went ahead and changed brake pads.
Centric lists same front rotor for 4WD and RWD 2 piece design. So, if you have centric 2 piece front wheel hub, then I'm sure you can put any brand front rotors made of 4WD F150.
I'd say that is very good design.
