Multifunction switch connector
Old May 11, 2018 | 10:29 AM
brandon_oma#692's Avatar
brandon_oma#692
Looking for ideas on how to keep this together. Connector for the turn signal switch. I really don't want to splice in a new connector pigtail or glue it.
Old May 11, 2018 | 10:39 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Have you tried a zip tie that went under the wires on the gray connector and over the black part which will be held in place by the cover a bit?
Maybe take the two mounting screws at the top of the black piece and put a ring terminal in there and use that as tie downs for the zip tie around the gray connector?
Old May 11, 2018 | 10:40 AM
ArmyLifer's Avatar
ArmyLifer
I had the same thing happen on my MFS connector when I was checking for the chafed OD wire. Broke off the retaining clip. I plugged it back in and just let it ride. Been almost a year now with no problems. If I ever have connectivity issues I’ll revisit a proper solution.
Old May 11, 2018 | 10:48 AM
brandon_oma#692
Haven't tried anything yet. Just pulled it apart before leaving for work. Turn signals quit working last weekend on my way home from the races. Replaced flasher first then found this. If you tilt the wheel a few times it works itself loose .
Old May 11, 2018 | 10:51 AM
brandon_oma#692
Good ideas thanks
Old May 11, 2018 | 02:49 PM
Walleye Hunter's Avatar
Walleye Hunter
You could get a new pigtail and just swap out the block. The wires come out pretty easy with something like a dental pick. Apparently that's a pretty common problem because my DD's was glued in place. Part number for the pigtail is 3U2Z-14S411-YNA
Idaho Highboy
22
Mar 30, 2022 12:30 AM
fixxxer-upper
Aug 2, 2019 12:33 PM
elkycali
May 9, 2016 08:52 AM
whateg01
1997 - 2003 F150
Sep 1, 2014 11:18 PM
Fishin76
Oct 21, 2009 09:54 PM
