My excursion keeps stalling
Old May 11, 2018 | 09:30 AM
Greent01's Avatar
Greent01
My 2002 Ford excursion keeps stalling on me and I have no idea what to check for now. Any ideas of what it might be?
I replaced the fuel pump a couple months ago, just replaced the fuel filter and got a new exhaust, and there’s no vacuum leaks. I have the triton V10 6.8L, it’s got 333,345 miles on it 4x4. No mods everything’s stock
Old May 11, 2018 | 09:44 AM
ArmyLifer's Avatar
ArmyLifer
More details needed. Miles, engine, any mods, tuners etc.
Old May 11, 2018 | 09:45 AM
rock2610d's Avatar
rock2610d
Gas diesel?
Old May 11, 2018 | 10:42 AM
Greent01's Avatar
Greent01
It’s the V10 6.8L it’s got 333,345 miles on it, no mods or tunes
Old May 11, 2018 | 10:55 AM
pirate4x4_camo's Avatar
pirate4x4_camo
It is either loosing spark or fuel, because you recently messed with the fuel system that is where I would start.
actually I would start by pulling the error codes.
Old May 11, 2018 | 10:57 AM
Greent01's Avatar
Greent01
I had one code say the output speed shaft sensor was bad or something but don’t know which one or if it would cause it stall
Old May 11, 2018 | 11:20 AM
pirate4x4_camo
Recently had a speed sensor error code and it turned out the sensor itself was fine but one of the grounds in the engine compartment was bad. In this case it didn’t cause stalling but did cause intermittent operation of the lights and instrument cluster.
Old May 11, 2018 | 12:29 PM
rock2610d's Avatar
rock2610d
Yup, check your recent work.
Typically I have found poor attention to details cause problems.
I would check the "new" exhaust as it might be hitting a wire like O2 sensors. Shorting something out.
Make sure the fuel pump wires are not melted or shorting out on new exhaust.
Old May 16, 2018 | 05:43 AM
Greent01's Avatar
Greent01
Alright, and where are the speed sensors located?
IronDioPriest
Aug 27, 2018 02:17 PM
Bryan Tate
May 31, 2018 07:37 PM
bjvagts
Oct 9, 2014 10:22 PM
Myron Bennell
Dec 31, 2013 07:47 AM
ezriderrandy
Modular V10 (6.8l)
Sep 28, 2004 10:46 AM
