cruise/ABS common problem
Old May 10, 2018 | 10:50 PM
huckster's Avatar
huckster
I have a 04 Excursion that has a abs intermittent light and the cruise control won't stay on. I think the two are related somehow. Maybe a sensor on a wheel that measures the speed?? It seems like the cruise will cut out when I hit a bump in the road. Not a big bump, just a crack in the pavement will cause it to shut off. If the abs light goes out the cruise will be erratic and cause the truck to jerk and speedo fluctuate till it shuts down the cruise control. Can anyone offer a probable cause for this? I really believe the two are closely related.
thanks huckster
Old May 11, 2018 | 09:17 AM
96firephoenix's Avatar
96firephoenix
A sensor on the wheel that measures the speed? that would be your "Wheel Speed Sensor" Which does in fact help regulate the ABS. Some vehicles cut the cruise control if there's a fault in the ABS, so it looks like the excursion is one of those vehicles.
https://www.rockauto.com/en/catalog/...ed+sensor,1912
https://www.rockauto.com/en/catalog/...+assembly,1636
Old May 11, 2018 | 04:48 PM
seijirou's Avatar
seijirou
I believe the vehicle speed sensor is in the rear differential and is necessary for both cruise and ABS. Because you also see the speedo fluctuate, which is driven by the ABS computer that gets vehicle speed from the... vehicle speed sensor, that's the 1st place I'd look.
Old May 16, 2018 | 04:23 PM
huckster's Avatar
huckster
UPDATE........ My mechanic has had the tester gadget on it and found the rear differential sensor is bad. New sensor and still cruise not working right and abs light still on and confused mechanic dude. Anyone have a clue where to look next? I'm trying to keep this fix as inexpensive as possible but I'm getting a little concerned. Need some help guys.
Old May 17, 2018 | 06:59 AM
wpnaes's Avatar
wpnaes
Old May 17, 2018 | 11:54 AM
huckster's Avatar
huckster
Great info. thanks. The recall switch is the first thing he looked at. He said I'm ok there. After driving it a little more he said the abs light went out and the cruise started working right. Maybe a reset period?? Anyway he cleared the codes and so far the problem is gone. I keep an eye on it. Thanks a ton guys.
Old May 17, 2018 | 05:14 PM
huckster's Avatar
huckster
Well dangit. The ABS light is back on but the cruise seems to be working. dangit! ideas??
Old May 21, 2018 | 09:27 AM
96firephoenix
Is it the rear sensor again? Might be boogered wiring.
62FE4x4
May 25, 2016 06:33 AM
Donald6487
Dec 9, 2015 06:59 PM
berick
Jun 11, 2012 03:06 PM
run6.0run
Feb 28, 2012 04:32 PM
bigpowerstroke
Nov 8, 2010 12:27 PM
